Wireless
8533 ディスカッション
Where to get Linux driver for Intel® Wi-Fi 6 AX101?
AX101
初心者
24,804件の閲覧回数
Hello @Albert_R_Intel ,
From Intel® Wi-Fi 6 AX101 Product Specifications:
https://ark.intel.com/content/www/us/en/ark/products/203014/intel-wifi-6-ax101.html
It's said Linux is Supported. however there is no way to get the driver in the following two links:
https://www.intel.com/content/www/us/en/support/articles/000005511/wireless.html
https://wireless.wiki.kernel.org/en/users/drivers/iwlwifi
I got  "Intel® Wi-Fi 6 AX101" preinstalled in a Mini PC.
I installed "Fedora Linux 37 (Workstation Edition)", the "Intel® Wi-Fi 6 AX101" failed to work.
Attached "fedora SSU.txt", "lspci.txt", "inxi.txt".
A AX101 User
0 件の賞賛
13 返答(返信)
Alberto_R_Intel
従業員
24,722件の閲覧回数
AX101, Thank you for posting in the Intel® Communities Support.
I will do further research on this matter, in order to confirm if we can provide the driver you are looking for or if there are other options for you to be able to download it.
As soon as I get any updates, I will post all the details on this thread.
Albert R.
Alberto_R_Intel
従業員
24,657件の閲覧回数
Hello AX101, I just received an update on this matter.
After reviewing the case, it is important to mention that AX101 driver/firmware is available in the newer (and stable) kernels (e.g. kernel 6.1 or 6.2) to obtain the latest firmware version 72.
Albert R.
Dezhen
初心者
24,620件の閲覧回数
Hello
I have updated to the latest firmware and linux-kernel 6.2.5, but the wireless network is still not available.
Dezhen
Dezhen
初心者
24,619件の閲覧回数
This is my device information.
Alberto_R_Intel
従業員
24,570件の閲覧回数
Dezhen, Thank you for posting in the Intel® Communities Support.
Please submit your inquiry on a new thread, the reason for this is that every scenario is different even if the same product is being used, so for us to better assist you and in order to try to fix the problem, please submit a new thread:
https://communities.intel.com/community/tech
Let me apologize for any inconvenience.
Albert R.
Alberto_R_Intel
従業員
24,465件の閲覧回数
Hello AX101, I just wanted to check if the information posted previously was useful for you and if you need further assistance on this matter?
Albert R.
AX101
初心者
24,402件の閲覧回数
Hello @Alberto_R_Intel ,
Upgrade to 6.3.0-0.rc2.20230314gtfc89d7fb.223.vanilla.fc37.x86_64, the AX101 wireless card still does not working.
There are some message from dmesg:
[ 5.774130] iwlwifi 0000:00:14.3: Detected Intel(R) Wi-Fi 6 AX101, REV=0x351
[ 6.958878] iwlwifi 0000:00:14.3: Loaded firmware version: 74.a5e9588b.0 QuZ-a0-hr-b0-74.ucode
Please see detail in attached log.
A AX101 User
Alberto_R_Intel
従業員
24,302件の閲覧回数
Hello AX101, Thank you very much for sharing those results.
We are sorry to hear the issue persists after trying the suggestions provided previously.
We will continue working on this matter and provide a response as soon as possible.
Albert R.
Alberto_R_Intel
従業員
24,024件の閲覧回数
After reviewing the case, it is important to mention that the Intel® AX101 card is a newer wireless product. Based on that, what we suggest for this scenario, will be to install the latest AX101 firmware from backport-iwlwifi.
Albert R.
AX101
初心者
23,872件の閲覧回数
Thanks for the update. Do you have some guide of how to use backport-iwlwifi?
A AX101 User
Alberto_R_Intel
従業員
23,859件の閲覧回数
Hello AX101, Thank you very much for your response.
In regard to your question, I will double-check on those details and provide a response as soon as possible.
Albert R.
Alberto_R_Intel
従業員
23,819件の閲覧回数
In reference to your question, please get in contact directly with the system manufacturer for further recommendations on how to use backport-iwlwifi:
http://www.azw-online.com/
Albert R.
gendis_ax101
ビギナー
17,808件の閲覧回数
I am having the very same issue with a Debian based system. Did you ever find a driver for the "mini" pc. I feel I purchased the same device as you.
thanks,
another_ AX101_ user.
返信
