Hello caf
Thank you for posting on the Intel️® communities. Please share with us the following information:
- Did you check the router configuration with the ISP?
- Did you check Windows 11* compatibility with the laptop manufacturer?
- Did you try using different drivers? What versions?
- Is this the original adapter that came pre-installed in your system or have you changed/installed a new adapter recently?
- Have you checked if this issue happens on different networks?
- Were you able to have you wireless connection in a normal/expected performance before?
- Have you installed any recent software or hardware in your system?
- Have tried a roll back to a previous driver version for testing?
- Have you rebooted your access-point, router, modem?
David G
David G.
Thank you for the update. The Intel® Dual Band Wireless-AC 3160 does not support WIFI 6 speeds, a driver change will not make it compatible with that version. The wireless Intel wireless cards that support those speeds are:
- Intel® Wi-Fi 6 Series
You need to check the router configurations with your ISP to change to a configuration that's supported for your wireless card.
David G.
Protocols are backward compatible with other protocols, so usually AX routers are able to work with AC. Please make sure that all the system is updated, regarding drivers, OS and BIOS. Make sure that you're also using the Recommended Settings for 802.11ac Connectivity
If that doesn't work, check with the ISP for further assistance with the new router/ap.
David G
David G.
https://community.intel.com/t5/Wireless/Issues-with-Intel-R-Dual-Band-Wireless-AC-3160/m-p/1531569
![](/skins/images/C4F7392A5C68ACA60290C9576F107044/responsive_peak/images/icon_anonymous_message.png)
