I have an ASUS G751JT laptop which is still going strong. I just replaced my wireless router with an ASUS ZenWiFi Pro XT12 router. Now my laptop with an Intel wireless AC 7260 does not see any of the three bands; 2.4, 5-1 and 5-2. I would like to get the latest driver for the AC 7260. Any help would be appreciated.
Thank you.
For the link, check your Private Message inbox. Click on your avatar picture in the top right corner of the page (in the Communities blue banner) and select Messages from the resulting menu.
P.S. You are the 193rd WLAN Driver requestor since Jan. 6th.
According to my receipts, it was sent to you. You are checking your Intel Communities Private Messages (PM) inbox, right? This isn't to your normal email inbox.
Found it.
I was checking the inbox of the other avatar next to the language symbol as opposed to the communities inbox.
Thank you for the drivers!
I installed the drivers and got 802.11n working.
Thank you so much for providing the drivers even though Intel pulled it off their website.
Hi Scott,
Could you send me a link to the Intel AC 7260 drivers as well.
I also need the Win10x64 driver for the AC-7260.
Would be great if you can drop me that in a PM.
Thanks in advance
@JamesHowlett and @Lantash,
P.S. You are the 194th and 195th WLAN Driver requestors since Jan. 6th.
P.S. You are the 197th WLAN Driver requestor since Jan. 6th.
I'm also looking for the Intel AC7260 driver.
Thanks so much for help all of us!
It cured issue on my Asus as well.
Checked 18.33.17. 1 using manual driver update.
https://www.catalog.update.microsoft.com/Search.aspx?q=ac-7260
P.S. You are the 198th WLAN Driver requestor since Jan. 6th.
It's good that I came across this topic, recently encountered the same problem, thanks for your help)
I also need drivers for ac 7260 (n). win10 64bit
Hey @n_scott_pearson !
Looks like I need help with a driver for the AC 7260 card also. Thanks!
P.S. You are the 202nd WLAN Driver requestor since Jan. 6th.
P.S. You are the 203rd WLAN Driver requestor since Jan. 6th.
Hi Scott! Thank you for your professional support here!! You helped me before. I have a problem. My Bluetooth is Switched OFF which means that my drivers are outdated. Do not know is it Intel or Microsoft with updates that did that. AC 7260 is not supported and drivers removed from Intels support page. Not sure what to do here, and will it help to attempt to reinstall the drivers. Tried the update from device manager, but windows 10 64bit complained that those could not be executed due to error. No further explanation. Toggle button in Win is gone too. Could I have the drivers
Intel® Dual Band Wireless-AC 7260
Or do you have any other suggestions??
Cheers Dean!
