Wireless
8514 Discussões
Wireless AC 9560 - Wifi Connections Rejected - part 2
StefanoBordoni
Novo colaborador I
1.324 Visualizações
Almost a month ago, I wrote this thread reporting my problems using the new drivers.
Just when I was resigned to not being able to use the new Intel Wireless drivers (22.0.0 included), I stumbled upon the solution.
The first step was the command ‘gpupdate’ from the administrative command prompt. This restored the connection with my commonly used wifi network.
The second step was to reset the Hyper-V default switch.
To do this, I disabled every default switch related entries from the Device Manager network cards.
Then I opened the Hyper-V Manager, and I selected ‘default switch’ entry from the Virtual Switch Manager, and I clicked the ‘Remove’ button.
This operation failed with an error, but it also reset the previously disabled default switch items.
From this very point (2 days ago), the new drivers have no more connection issues.
I hope it may help.
3 Respostas
Maria_R_Intel
Moderador
1.308 Visualizações
Hello StefanoBordoni,
We are glad to know you found a solution, thank you for taking the time to share this fix, and hopefully, it may help other community members experiencing similar behavior. Since the thread is now solved, we will proceed to close it.
If you need any additional information, please submit a new question as this thread will no longer being monitored.
Maria R.
StefanoBordoni
Novo colaborador I
1.285 Visualizações
I discovered some days ago, that, sadly, it is a temporary solution.
Quite randomly, the problem pops up without any evident event...
...up to now, I reverted to the root (working) drivers.
StefanoBordoni
Novo colaborador I
1.222 Visualizações
Responder
