Wireless
告知
8567 ディスカッション
Wireless AC 9560 - Wifi Connections Rejected
StefanoBordoni
新規コントリビューター I
20,354件の閲覧回数
I had several issues on my notebook ASUS GL703GM with Windows 10 Pro 64-bit with all lastest v2004 updates.
  • connection laziness at the system startup.
  • I wasn't able to connect to 2.4ghz wifi networks anymore.
  • I wasn't able to change the router with the same wifi settings.
  • and finally, I cannot connect to any known wifi.  It continues to ask me the password...
I reset connections, TCPIP stack... but nothing.
My solution was uninstalling and removing wifi drivers until the Windows 10 2004 64-bits built-in ones (v21.10.2.2).
[<win>+x, select Device Manager, select the wifi card, right-click, select uninstall, and check 'remove drivers']
With these drivers, everything is working fine without any problem.
Then Windows Update applied v21.80 and the problems rose again.
Again I downgraded to v21.10.2.2 by the device manager, and the problems disappeared again.
As far as I could see, these problems are present at least in these versions:
  • 21.40
  • 21.80
  • 21.90
  • 21.110
  • 21.120
A last detail that might help is that I have Core Isolation enabled.
0 件の賞賛
1 解決策
StefanoBordoni
新規コントリビューター I
19,690件の閲覧回数
Several days later, connection problems suddenly popped up... and I was forced to roll back to root drivers.
Yesterday I tried the latest Wifi drivers (22.30 64 bits) and they have the usual connection problems (on both 2.4 & 5ghz).
Again I had to roll back to root drivers...
Then I gave a look at the Reliability History report and I noted that I have a problem with Window Wireless LAN 802.11 Extensibility Framework crashing during the startup.
Looking at the Event Viewer I discovered that it is something related to INTELWIFIIHV08.DLL (found in my 'System32' folder).
After a short investigation, I discovered that it is a file included in the root driver package but not in the latest drivers.
I also noted that these crashes also occurred during my driver update test...
Then I re-installed the latest drivers, and I renamed the DLL.
After the reboot, my WiFi connection problems disappeared.
Up to now, the device appears working, fast, and responsive...
...Maybe I am lucky this time.
元の投稿で解決策を見る
34 返答(返信)
Jim_Panse
ビギナー
4,518件の閲覧回数
I have exactly the same problem. But the solution described does not work for me. I also found the INTELWIFIIHV08.DLL under System32. Which file has to be renamed? I would be very grateful for a hint. Thank you very much!
StefanoBordoni
新規コントリビューター I
4,477件の閲覧回数
In my case, I renamed that file in something like (*.dll_) and rebooted.
This solved my problem.
ps: after 4-5 weeks, I deleted the renamed file.
StefanoBordoni
新規コントリビューター I
4,156件の閲覧回数
In my case,
  • I installed the latest drivers
  • I went to the system32 and I renamed "INTELWIFIIHV08.DLL" into something like "_INTELWIFIIHV08.DLL_" (in this way you can always restore it with minimal effort).
  • reboot.
  • from this point, my WIFI started to work fine
It is about 3 months that I haven't connection problems anymore.
(after the first 2 running-fine weeks, I also deleted the renamed file)
Good luck
Jim_Panse
ビギナー
4,092件の閲覧回数
StefanoBordoni thanks for your replies.
I tried exactly these steps for several times without success.
Driver Version 22.50.1.1 on HP ZBook 17 G5 with Windows 10 Enterprise 21H1
Downgrade to driver version 21.10.2.2 = everything works fine.
Using a Ubuntu Live CD = everything works fine.
Should anyone still have an idea, I would be very grateful.
HP Support couldn't help me, so the Intel Community is my last hope.
StefanoBordoni
新規コントリビューター I
4,087件の閲覧回数
... if you didn't already do, you can try the following steps:
  • starting from v21.10.2.2, install latest drivers
  • rename the file
  • reboot
  • try your wifi
  • if it still doesn't work, you can try a 'network reset' from 'network & internet' settings (at the end of the page)
  • reboot again
  • try your wifi
If it still fails, you can try to look for some evident problem from Reliability Report.
StefanoBordoni
新規コントリビューター I
4,057件の閲覧回数
Sometimes the antivirus might be corrupted or unstable, and removing it to re-install it from scratch can be a good idea.
Another idea can be viewing again the Reliability History report and look for any unusual event.
Another step I took when struggling with my wifi card was to buy a USB WiFi card as an 'option omega' solution.
The interesting side is that it is something you can use on any PC.
William_2021
ビギナー
3,991件の閲覧回数
It took a LOT of working with the Intel support engineers but Intel was able to identify the  problem with the 9560 driver and will be releasing  a fix for this in November, 2021 driver update is what I was told.
StefanoBordoni
新規コントリビューター I
3,984件の閲覧回数
StefanoBordoni
新規コントリビューター I
3,875件の閲覧回数
New drivers are published today.
The change lot is not so clear but let's hope they include the fix.
William_2021
ビギナー
3,872件の閲覧回数
The Intel Tech said the fix will not be out until Release 22.100.0.  So I'm still waiting.
StefanoBordoni
新規コントリビューター I
3,870件の閲覧回数
hmmm... it sounds like something around December/January driver release.
StefanoBordoni
新規コントリビューター I
3,787件の閲覧回数
Finally v22.100.0 are published... and they seem working smoothly (for now).
PS: the funny thing is that 3 weeks ago I changed my flagship notebook ... with no Intel HW inside.
William_2021
ビギナー
3,782件の閲覧回数
Yes, Very similar story with me. but Glad it's working for now.
StefanoBordoni
新規コントリビューター I
3,773件の閲覧回数
we spoke too early...
After only a day, the problem is again here.
I will revert to v21.80...
返信
