Wireless
8716 Discussions
ax200 hase 2 connectors, my HP Laptop only 1. Wich one to use?
VBREH
AlHill
Are you attempting to upgrade the wifi in your HP laptop without consulting with HP?
If so, you need to consult with HP.
https://www.intel.com/content/www/us/en/support/articles/000005687/network-and-i-o/wireless-networking.html
What is the laptop model number (complete)?
What processor model number?
What OS? Windows 10? What version? 1909?
What wifi came with the laptop?
Doc
VBREH
HP Pavilion 15-cs0211ng
Laptop is open, back cant look
Win10 1909
HP P/N 915620-001
U98H 132.00 Rev08
AlHill
Download, run, and ATTACH (using the paperclip) the results of this utility.
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then, an Intel support engineer can assist you.
Doc
LeonWaksman
Hi @VBREH​
  1. In case that the AX200 is compatible with your laptop interface and you have it already, you should connect the antenna cable to the connector marked 1(AUX). This connector is responsible for WiFi 2.4GHz + Bluetooth functionality.
  2. The other connector marked 2 (main) is for 5GHz WiFi functionality.
  3. Note that this is 2x2 Wi-Fi adapter. This means both antennas need to be connected to achieve the optimal Wi-Fi performance. So, my advice is to connect two anntennas.
  4. You may buy additional antenna: https://www.amazon.com/HUYUN-Antenna-Cable-Module-Internal/dp/B07DB6ZG3B/ref=sr_1_3?keywords=wifi+antenna+for+ax200&qid=1581452502&sr=8-3
Leon
VBREH
Not compatible. Will send back. Laptop dont start.
Thank You
AlHill
Well, you can "make" it work, but it is not something I recommend. And, this is why I said you must consult with HP for compatibility.
Doc
