Wireless
7646 Discussions
bluetooth problem in Intel® Dual Band Wireless-AC 7265 rev d
biradar
hello,
recently i purchased TP Link Archer T5E and found that its intel chip namely: Intel® Dual Band Wireless-AC 7265 rev d , wifi works smoothly but bluetooth was not working properly then i installed INTEL DSA it installed the drivers but it did not worked.
PROBLEM WITH BLUETOOTH: when i try to connect any device device gets connected but after few seconds specifically 1-2 seconds gets disconnected.
but recently i installed kali linux (dualboot) and in this os bluetooth works perfectly fine.
And i am attaching SUS txt file.
bluetooth driver version: 20.100.10.11
LeonWaksman
Hi @biradar
1. Download and install the BT-23.40.0-64UWD-Win10-Win11.exe . This is the latest BT driver for AC 7265 adapter (Windows 11).
2. Download and install the WiFi-23.40.0-Driver64-Win10-Win11.exeThis is the latest WiFi driver for AC 7265 adapter (Windows 11).
Leon
biradar
i did a clean installation of both the drivers(wifi and bt) and did a reboot still the same issue with Bluetooth.
i checked the driver version in device manager and it still is the same as previous...
im attaching few pictures from device manger
(wifi works fine)
one thing more let me put it in steps:
#open BT from quick settings and paired the device >BT issue >keeping BT open did a reboot >after booting the device it gets connected automatically and worked (to check i shared files to my phone) >closed BT from quick settings did a reboot >after it boots i open BT from quick settings >tries to connect the same issue.
Kenino
New User
Please kindly help me configure my PC. BT is failing to update to the new version. I keep getting an error when installing.
LeonWaksman
Hi @Kenino
Since you have also AC 7265 adapter and 64 bit Windows 10 Pro O.S., you should download the same drivers as mentioned in my post above. Because you have problems with the installation, try to perform Clean Driver Installation of the BT Driver and the WiFi Driver
Leon
