Hi NeoFonacot,
Thank you for reaching out to us regarding the issue you’re experiencing with your system. To better assist you, I need to gather some additional information. Could you please answer the following questions?
- Has this issue occurred before?
- Can you please run the System Support Utility (SSU) and share the logs with me?
Providing this information will help me diagnose the system more accurately and check for available solutions.
Intel® Driver & Support Assistant (Intel® DSA) showing this error code 1603 when trying to update the intel wireless adapter: One or more issues caused the setup to fail. Please fix the issues and then retry setup.
Error code 1603: This is a general error; it can be anything from an exception in code to a problem with the setup.xml. For specific identification of the error, I need to review the log for further details. You may share the log with me so I can review it further to see if there are any additional details to provide.
Randy T.
Hi NeoFonacot,
I wanted to follow up regarding the questions and information we shared with you recently. Have you had a chance to review them? Your feedback is invaluable in helping us determine the next best course of action.
Please let me know if you have any thoughts or if there's anything else you need from us.
Looking forward to your response!
Randy T.
Hi NeoFonacot,
Since I have not received any response from you, I will proceed with closing this ticket. Please note that this case will no longer be monitored.
If you have any new questions or inquiries, kindly submit another ticket, and we will be happy to assist you.
Randy T.
