Wireless
8508 討論
my new modeum
GregRasmussen
初學者
634 檢視
I got a new xfinity modem and it does not show up in the setting section when trying to install it
0 積分
8 回應
AlHill
超級使用者
616 檢視
Contact xfinity for help setting up their modem.
[AI is the same as snake-oil]
GregRasmussen
初學者
609 檢視
it shows under available networks on all other devices except my laptop.
AlHill
超級使用者
601 檢視
This site does not provide support in setting up routers/modems.  You need to configure your router correctly for "all other devices" to be able to access it.
GregRasmussen
初學者
608 檢視
the problem is i think in the laptop itself
AlHill
超級使用者
592 檢視
Have you configured your wireless connection correctly?  The correct SSID?
What is your OS and what wifi card do you have?  Did this laptop work before and you just changed routers?
GregRasmussen
初學者
557 檢視
i am using the ethernet connection right now. the wifi worked fine when i was using the old router so it is not the router. i have an intel(R) Dual Band Wireless-AC 3160
AlHill
超級使用者
553 檢視
That is a pretty old wireless card.  I am tagging @n_scott_pearson regarding a possible driver issue for the ac-3160.
n_scott_pearson
超級使用者
517 檢視
I have the final drivers for this adapter in my share (here). Make sure you are using the final drivers as you won't have support for the newer routers without it.
Hope this helps,
回覆
