Wireless
8510 Discussões
my new modeum
GregRasmussen
Principiante
647 Visualizações
I got a new xfinity modem and it does not show up in the setting section when trying to install it
8 Respostas
AlHill
Superusuário
629 Visualizações
Contact xfinity for help setting up their modem.
[AI is the same as snake-oil]
GregRasmussen
Principiante
622 Visualizações
it shows under available networks on all other devices except my laptop.
AlHill
Superusuário
614 Visualizações
This site does not provide support in setting up routers/modems.  You need to configure your router correctly for "all other devices" to be able to access it.
GregRasmussen
Principiante
621 Visualizações
the problem is i think in the laptop itself
AlHill
Superusuário
605 Visualizações
Have you configured your wireless connection correctly?  The correct SSID?
What is your OS and what wifi card do you have?  Did this laptop work before and you just changed routers?
GregRasmussen
Principiante
570 Visualizações
i am using the ethernet connection right now. the wifi worked fine when i was using the old router so it is not the router. i have an intel(R) Dual Band Wireless-AC 3160
AlHill
Superusuário
566 Visualizações
That is a pretty old wireless card.  I am tagging @n_scott_pearson regarding a possible driver issue for the ac-3160.
n_scott_pearson
Superusuário
530 Visualizações
I have the final drivers for this adapter in my share (here). Make sure you are using the final drivers as you won't have support for the newer routers without it.
Hope this helps,
Responder
