Wireless
8511 Discusiones
my new modeum
GregRasmussen
Principiante
650 Vistas
I got a new xfinity modem and it does not show up in the setting section when trying to install it
0 kudos
8 Respuestas
AlHill
Superusuario
632 Vistas
Contact xfinity for help setting up their modem.
[AI is the same as snake-oil]
GregRasmussen
Principiante
625 Vistas
it shows under available networks on all other devices except my laptop.
AlHill
Superusuario
617 Vistas
This site does not provide support in setting up routers/modems.  You need to configure your router correctly for "all other devices" to be able to access it.
GregRasmussen
Principiante
624 Vistas
the problem is i think in the laptop itself
AlHill
Superusuario
608 Vistas
Have you configured your wireless connection correctly?  The correct SSID?
What is your OS and what wifi card do you have?  Did this laptop work before and you just changed routers?
GregRasmussen
Principiante
573 Vistas
i am using the ethernet connection right now. the wifi worked fine when i was using the old router so it is not the router. i have an intel(R) Dual Band Wireless-AC 3160
AlHill
Superusuario
569 Vistas
That is a pretty old wireless card.  I am tagging @n_scott_pearson regarding a possible driver issue for the ac-3160.
n_scott_pearson
Superusuario
533 Vistas
I have the final drivers for this adapter in my share (here). Make sure you are using the final drivers as you won't have support for the newer routers without it.
Hope this helps,
Responder
