Contact xfinity for help setting up their modem.
[AI is the same as snake-oil]
it shows under available networks on all other devices except my laptop.
This site does not provide support in setting up routers/modems. You need to configure your router correctly for "all other devices" to be able to access it.
the problem is i think in the laptop itself
Have you configured your wireless connection correctly? The correct SSID?
What is your OS and what wifi card do you have? Did this laptop work before and you just changed routers?
i am using the ethernet connection right now. the wifi worked fine when i was using the old router so it is not the router. i have an intel(R) Dual Band Wireless-AC 3160
That is a pretty old wireless card. I am tagging @n_scott_pearson regarding a possible driver issue for the ac-3160.
I have the final drivers for this adapter in my share (here). Make sure you are using the final drivers as you won't have support for the newer routers without it.
Hope this helps,
