Dear Sir/Madam,
I couldn't find what the hardware requirements for wifi 7 are(for example can a 8th gen intel cpu support wifi 7, does the PC need to have a specififc type of wifi antenna to support the higher throughput and the 6Ghz range?).
In the same spirit can a 8th gen intel cpu support wifi 6E gig+ AX411 or is it limited to the AX210 protocol?
In general what is the highest wifi standart that an 8th gen intel cpu can support?
If the cpu generation is not sufficent information for the answer to the questions, the laptop I intend to upgrade is a HP Pavillion x360 14-cd008nv.
Also are vPro products intended for the average consmer or are they just for corporate use applications? If they are intended for the general consumer what do they offer over non vPro products?
Thanks for taking the time to answer,
sinsirely George.
Hello GeorgeChat,
We wanted to inform you that, regarding the hardware requirements for any wireless adapter and processor, it is your motherboard manufacturer that can provide you with what is compatible with their product.
In short, when it comes to compatibility, it is best that you contact your system manufacturer, as they are the ones who configure the motherboard or system.
For more information, please check out this link:
Furthermore, as for the vPro platform, the Intel vPro platform provides unique value to every segment of the computing ecosystem:
- For business PC users, the Intel vPro platform provides a premium computing experience, enabling high productivity in the workplace.
- For businesses, the Intel vPro platform provides flexible management, hardware-enhanced security, and improved stability. These bring confidence, peace of mind, and control over computing infrastructure.
- For system manufacturers, the Intel vPro platform becomes a framework for developing and delivering business-optimized computing to the marketplace.
- For service providers, the Intel vPro platform offers mechanisms for adding value to PC deployment and infrastructure management services.
- For software developers, the Intel vPro platform provides numerous opportunities to enhance business solutions with hardware-hardened capabilities.
For more information, you may check out this link as well:
And if you have any questions, please let me know.
Carmona A.
Thanks for the help, i've contacted my computer's manufacturer and they've said:
"The Intel BE200 non-vPro might work, as may the Intel AX210 non-vPro, since your notebook has the Intel 7265 AC Wi-Fi adapter which requires two antenna wires to work properly. No guarantees though".
I suspect since the laptop has the "hardware"(dual-antena adapter) they are concerned if components will "play together nicely" software wise. So since Intel is the manufacturer of both the 7265 AC Wi-Fi adapter and the Wi-Fi BE200 M.2 2230 Wi-Fi 7 + Bluetooth 5.4 non-vPro WW WLAN module I am hoping to intall.
The Question is: Are these components compatible witheach other?
Thanks beforehand,
George.
- An 8th gen i5/i7 processor should be able to support WiFi7.
- The AX411 component requires a 600/700 Series chipset with CNVio2 support - which you don't have.
- Can't say beyond WiFi7.
- vPro is essentially a Corporate technology, but does have application wherein sophisticated consumers use it to manage multiple PCs. It requires vPro-enabled Processor, Chipset and Motherboard.
- I believe that using a vPro-enabled WiFi module in a non-vPro system will simply result in the vPro features of this module being ignored (meaning it runs like the non-vPro version).
Hope this helps,
Hi Scott,
Thanks for taking the time to answer, your reply was really helpfull.
If you have any insight on the compatibillity of the components on my reply to @ACarmona_Intel comment any help would be greatly appreciated.
Thanks again,
George.
Hello GeorgeChat,
Thank you so much for the response.
I will raise the case with our engineers so we can provide you with an accurate response to your concern, and I will get back to you once the update is available.
In addition, one of our super users, @n_scott_pearson, has addressed your concern; kindly review it as you might find it useful.
Thank you for your patience.
Carmona A.
Hello GeorgeChat,
Thank you so much for patiently waiting on our response.
We wanted to inform you that it's important to note that compatibility is not solely determined by the number of antenna wires. It also depends on other factors such as motherboard specifications, BIOS support, and potential software interactions. While both the 7265 AC Wi-Fi adapter and the Wi-Fi BE200 M.2 2230 Wi-Fi 7 + Bluetooth 5.4 non-vPro WW WLAN module are manufactured by Intel, this does not automatically guarantee compatibility.
The manufacturer's statement indicates a cautious approach, suggesting that while the hardware may be physically compatible, they cannot assure that the components will function together without issues. This is often the case with hardware upgrades, where the combination of new and existing components may require specific drivers or software configurations to work correctly.
In conclusion, while there is a possibility of compatibility due to the shared manufacturer and the presence of dual antenna wires, it is recommended to seek further confirmation from the system or motherboard manufacturer for a definitive answer on compatibility. They would have the most accurate information regarding the system's configuration and the potential for any compatibility issues with the wireless cards.
References:
- Type of Wi-Fi Antenna Connectors Required for Intel® Wireless Cards
- Why Doesn't My Laptop Recognise My New Intel® Wireless Adapter?
- Regulatory Information Regarding Wireless Hardware Installation or Upgrade
If you have other questions, please let me know.
Carmona A.
Hello GeorgeChat,
We would like to know if you have any questions regarding the recommendation that we have provided.
If so, kindly inform me, as we would be glad to assist you.
Carmona A.
Hello GeorgeChat,
Again, we would like to know if you have any questions regarding the recommendation that we have provided.
Carmona A.
Sorry for the late reply but I've drowning in deadlines lately.
Although I have not been to attempt the install I've gotten some of the answers I was looking for through our conversation even though I didn't get the clear answer I was hoping for, for the time being don't have any other questions on this matter.
When I do attempt the install and may have more questions I will reach out
George
Hello GeorgeChat,
Thank you so much for the update, and no worries; we understand your situation.
It seems that the answer that you were looking for can only be answered directly by your system manufacturer, which means that before attempting to install, we recommend that you contact your system manufacturer again for compatibility validation.
To summarize, we advise that you keep in touch with your system manufacturer.
Carmona A.
![](/skins/images/7FC17B7B85029576C25F1E43CE255B51/responsive_peak/images/icon_anonymous_message.png)
