Wireless
8537 Discussions
wifi driver issues
junayed
So I'm using a Cudy WR3000 v.1 wifi card, which uses ax200 chi. The problem is I'm getting micro stutterings, and many of y'all are saying that it's because of the drive. Is there a stable driver available for this specific Wi-Fi card? Please let me know. If the driver fixes my issue, I don't have to buy a new wifi card
JeanetteC_Intel
Hello junayed,
To get a better understanding of the issue and be able to provide an effective recommendation, please provide the missing key information here:
  1. Is this a newly purchased system device with out-of-the-box issue, or has it previously worked fine before he micro stuttering started?
  2. Is the wireless adapter pre-installed on your device or is it an upgrade/replacement component?
  3. Is the issue only happening when connected to Cudy WR3000 v.1 and not happening when connected to another wireless network?
  4. Are they any other device(s) connected to Cudy WR3000 v.1 and not getting the same issue?
Additionally, I highly appreciate you sharing your system configuration so I can fully check and provide you with an accurate fix. This could be possible by downloading the Intel® System Support Utility for Windows* software. When the download is complete, launch SSU.exe.
  • Click Scan.
  • Click Save. *Attach the SSU log file as you reply.
JeanetteC.
JeanetteC_Intel
Hello junayed,
Let us know if you have any questions.
JeanetteC.
