I am getting a 100% repeatable BSOD on Windows 7 running Amplifier 2015 Update 1 (build 380310), native code.
Advanced Hotspots ->Hotspots -> NO PROBLEM
Advanced Hotspots ->Hotspots , stacks and context switches ->BSOD after a few seconds.
Suggestions?
- « Previous
- Next »
PM sent with FTP link
@vasci_
Would you please run a sort of reversed experiment: enable call stacks, but disable context switches?
We need to see the picture from different angles. Thanks!
@vasci_ , @Peter Wang
I suppose that this piece of x64 assembly code could be a culprit of the BugCheck 0x101. It seems like some kind of spin-wait loop on variable which is executed by the machine code shown below. This is CPU #7 which is running Solver.exe process threads.Thread fffffa8024f41060 is in running state with RIP pointing to vtss+0x11691 (fffff882`1065d691 4885c0 test rax,rax) instruction which is performing spin-wait loop. Could this be a cuse of CPU6 hang?
6: kd> u @rip
vtss+0x11691:
fffff882`1065d694 75f2 jne vtss+0x11688 (fffff882`1065d688)
fffff882`1065d696 f0480fbaab8800000000 lock bts qword ptr [rbx+88h],0
fffff882`1065d6a0 738c jae vtss+0x1162e (fffff882`1065d62e)
fffff882`1065d6a2 ebe4 jmp vtss+0x11688 (fffff882`1065d688)
fffff882`1065d6a4 4032ff xor dil,dil
fffff882`1065d6a7 ebb2 jmp vtss+0x1165b (fffff882`1065d65b)
fffff882`1065d6a9 488bc4 mov rax,rsp
6: kd> ub @rip+16
vtss+0x11688:
fffff882`1065d688 f390 pause
fffff882`1065d68a 488b8388000000 mov rax,qword ptr [rbx+88h]
@iliyapolak
I have forwarded your investigating result to the developer. Thank you.
PM send with link to new .DMP
@Peter
Do you have any info regarding BugCheck 0x101?
@iliyapolak
Thank you for data, but it is under investigating. I will update news if any process.
Thanks for updating.
See similar issue in this thread to get fixed vtss.sys and know *steps*, in last page.
Let me know if you still have this problem after upgrading to 2016 U2 with fixed vtss.sys. Thank you.
Things are working for me just fine now!
@ vasci_
I'm glad to know this, and thank you for quick response.
![](/skins/images/2E08A100FB92911314A240D1EAFB2828/responsive_peak/images/icon_anonymous_message.png)
- « Previous
- Next »
