I am trying to run vtune on my Ubuntu workstation.
I am not using a remote server. I get this error:
jimfrandeen@jimfrandeen-Ubuntu:~$ cd /opt/intel/oneapi/vtune/2023.0.0/bin64/
jimfrandeen@jimfrandeen-Ubuntu:/opt/intel/oneapi/vtune/2023.0.0/bin64$ ./vtune-gui
libva error: vaGetDriverNameByIndex() failed with unknown libva error, driver_name = (null)
[56029:0123/110623.983559:ERROR:cert_verify_proc_builtin.cc(690)] CertVerifyProcBuiltin for 127.0.0.1 failed:
----- Certificate i=0 (CN=jimfrandeen-Ubuntu) -----
ERROR: No matching issuer found
vtune gui comes up, but Configure Analysis never stops collecting data.
I was able to use vtune with a previous version.
Thank you for posting in Intel communities.
We tried opening Vtune-GUI form our side on a system with the following specification and it was running fine(refer screenshots)
The error which you are getting regarding the certificate issue can be ignored since Vtune is running locally.
Since we are unable to replicate your issue from our side can you get back to us with the following information:
1. OS details, Processor details
2. Sample reproducer code(A code which similar to your code which replicates the issue) on which you are performing the analysis
3. The exact steps you followed and the type of analysis you are performing
4. output of the self-checker logs. This can be obtained by running the below command:
/opt/intel/oneapi/vtune/2023.0.0/bin64/vtune-self-checker.sh
Thank You!
Varad
Could you please give us an update? Is your issue resolved?
Thank you.
Varad
We have not heard back from you. This thread will no longer be monitored by Intel. If you need further assistance, please post a new question.
Thank You!
Varad
![](/skins/images/7FC17B7B85029576C25F1E43CE255B51/responsive_peak/images/icon_anonymous_message.png)
