- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
I have made a program which works fine with Visual Studio 2013.
But when i tried to use the amplifier for getting the results it stopped and gave an error such as project exe stopped working.
I also checked amplifier for other programs it works fine.
But when i link this program with amplifier its giving an error.
iam not able to figure out this error why it has happened whether the error is in program or not.
Kindly help me in this regard.
Link kopiert
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi sairabanu :
What analysis type are you trying to use? If you are using the command line, what is your VTune Amplifier command line invocation? If you are using the graphical user interface, what are your project settings, that is, is VTune Amplifier launching your app? Are you attaching to a running process? Etc.? Need more details about what you are doing.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi Anderson
We are using Graphical interface and Vtune amplifier is launching or application.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Basic hotspots or advanced-hotspots or ???
Is it managed code, e.g., C#, or unmanaged, e.g., C/C++?
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi anderson,
we are running advanced hotspot with General exploration to determine the cache miss rate parameters of our program.
It is code in C.
I will send u the code as well as the file it required to run the code as attachment.
Kindly help in this regard.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
>>>But when i tried to use the amplifier for getting the results it stopped and gave an error such as project exe stopped working>>>
Can you provide more detailed description of that error?
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
