- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
I have installed VTune Profiler recently to profile an OpenCL project on VS2019. I need some help with how can I profile my code with VTune.
I could not find anything helpful yet. If I can get some document that discusses the step-by-step procedure starting from the welcome page, it would be very helpful for a newbie like me.
Gaurav.
Link kopiert
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Thank you for reaching out.
Refer the below link to know the step by step procedure.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hope we have answered your questions.Could you please give us an update?
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
I followed this document for profiling my OpenCL application, but I am unfortunately getting the error as attached.
- I selected my output .exe in Application
- And the relevant parameters in Application Parameters
- In the analysis type, I selected GPU Offload
I see the following error after I click Start.
Gaurav.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Thanks for the update.
Try the below code sample for GPU offload.If you get any error ,share the screenshot of it so that we could figure out the exact issue.
https://github.com/intel/BaseKit-code-samples/tree/master/VtuneProfiler/matrix_multiply_vtune
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Thanks for the immediate response.
Seems like your CPU based analysis is working fine.Did you try that code sample for GPU offload?
If not, try that and send the screenshot.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
This happens when application invokes other processes for which the user does not have read privileges ,so before running GPU offload uncheck the "Analyze child processes" option in the what pane in Vtune GUI.
Let us know if the issue persists.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
It gives the same error even after trying the suggested.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Is there something else that's causing the issue?
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Try running self checker script in vtune installed directory.Self checker script is to validate whether the appropriate drivers are installed and system is set up properly to collect performance data.You can find vtune-self-checker.sh script in <install-dir>/bin64. After running self checker script you will get a log file.
Also try in a standalone version and check whether you get the same error.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Can someone please help me with this? I am getting no clue.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
We have 2021.1-beta06 and we have self checker script in it.May I know your vtune version?
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Try installing the latest version of oneapi basekit for windows(https://dynamicinstaller.intel.com/oneapi/toolkits/base-kit/win/).After installing you will find vtune-self-checker.bat in the path intel/inteloneapi/vtune/bin64 .Run that file and let us know the update.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Kindly follow the procedures mentioned in the below link, also run vtune as well as command prompt with run as admin and let us know the updates.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Has this issue been resolved?Could you please give us an update?
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
