Analyzers
5248 Discussions
vtune 2021 0x40000024(no data) error for hardware event based sampling
111alan
21 215 Visites
Was testing some apps on an i7 11700K platform. Since the old parallel studio 2020 does not support this CPU any longer I installed the latest one-API. The problem is, the hardware event based sampling in all profiles stops working and throws a 0x40000024 no data error when finalizing. User mode sampling seems to have no issue.
The applications I'm trying to test work with older versions of vtune and cpu without a problem. And I've already updated the ME/chipset/serialio driver to the latest version listed on motherboard's vendor site(gigabyte Z590M gamingX). Any idea about what's the cause of this? Thanks.
0 Compliments
29 Réponses
AthiraM_Intel
Modérateur
15 882 Visites
Make sure that VTune self check script is running fine to validate that appropriate drivers are installed and the system is set up properly to collect performance data. See whether its working fine and share the log.
The self-check file for windows “vtune-self-checker.bat” and for linux “vtune-self-checker.sh” will be there in the <vtune-installation-directory>/bin64 folder if the VTune installation was done successfully.
Could you please let us know which version of vtune you are using?
Also share the OS details.
0 Compliments
AthiraM_Intel
Modérateur
15 821 Visites
We haven't heard back from you. Could you please give us an update ?
0 Compliments
111alan
15 812 Visites
Sorry for the delayed response. Currently the platform is at another place, but I've confirmed that Cascade lake platform has no issue with new vtune(2021.2) on the same system. I'll ask my friend to check on Cypress Cove platform again for me. Thank you for your suggestion, I'll reply again when I have the results.
0 Compliments
AthiraM_Intel
Modérateur
15 778 Visites
Thanks for the update. We will wait for your results.
0 Compliments
AthiraM_Intel
Modérateur
15 718 Visites
Did you get the results? Could you please give us an update?
0 Compliments
111alan
15 687 Visites
Just assembled the Icelake-SP platform. Seems that no luck as well. I ran the self test and there's quite a few errors and warnings. Attached are the log file and the output of the script.
Also I've installed and re-installed everything from Supermicro's motherboard driver page. The OS version is Windows10 20H2, vtune version is still 2021.2. Wondering what's not right here.
Thank you for your attention.
0 Compliments
AthiraM_Intel
Modérateur
15 640 Visites
Thanks for sharing the result.
Could you please install the latest version of Vtune (2021.3.0) and check whether the issue still persists.
You can download the latest vtune from the below link:
https://software.intel.com/content/www/us/en/develop/articles/oneapi-standalone-components.html#vtune
If the issue still persists please let us know.
0 Compliments
111alan
15 628 Visites
Just tried it, most of the errors are gone, but "HW event-based analysis (counting mode)" still fails. The "Microarchitecture Exploration" preset can finally finish properly, but there are still some problems I encountered:
1. "MEM_LOAD_RETIRED.L1_HIT" seems to be missing in the final result chart.
2. If I add more event counters(namely MEM_LOAD_RETIRED.L2_MISS and BR_INST_RETIRED.ALL_BRANCHES) into the microarchitecture exploration preset, the "microarchitecture exploration" summary page will disappear. I remember in the old version adding more counters won't disable any feature.
3. A gui bug shown below.
Thank you.
0 Compliments
111alan
15 602 Visites
My friend just tested it on Rocketlake. Also some failures  detected, mainly no-data error. Here are the log and output.
0 Compliments
AthiraM_Intel
Modérateur
15 597 Visites
We are checking on it internally, will get back to you soon.
0 Compliments
Kevin_O_Intel1
Employé
15 569 Visites
Can you run vtune_self_checker.sh >& log
And attach the log
0 Compliments
111alan
15 545 Visites
Is this log only acquirable in linux version? If so I'll install a Ubuntu and try this. Thanks.
0 Compliments
matthias-vigelius
Débutant
15 562 Visites
not the original poster but I'm having the same problem. I'm running the latest version 2021.3 on i7-1165g7 (tiger lake).
Please find attached the log.
Thanks heaps!
0 Compliments
Kevin_O_Intel1
Employé
15 531 Visites
Can you verify you are using vtune 2021 update 3.... this is the latest version of vtune and should support your processor
0 Compliments
matthias-vigelius
Débutant
15 524 Visites
Hi Kevin_O_Intel1,
I'm using version 2021.3.0, build 616728.
Thanks!
0 Compliments
Kevin_O_Intel1
Employé
15 514 Visites
You can run vtune-self-checker.bat on windows
0 Compliments
111alan
15 513 Visites
Then I already did, and the logs and script outputs are attached above.
0 Compliments
Kevin_O_Intel1
Employé
15 417 Visites
Can you zip and attach C:\Users\vigel\AppData\Local\Temp\vtune-tmp-vigel\self-checker-2021.05.25_14.13.45\
0 Compliments
111alan
15 409 Visites
Here, there's an additional txt inside for script outputs. Thanks.
0 Compliments
matthias-vigelius
Débutant
15 376 Visites
Here you go.. Thanks for taking care of it!
0 Compliments
Répondre
