Analyzers
5248 토론
vtune 2021 0x40000024(no data) error for hardware event based sampling
111alan
초보자
21,284 조회수
Was testing some apps on an i7 11700K platform. Since the old parallel studio 2020 does not support this CPU any longer I installed the latest one-API. The problem is, the hardware event based sampling in all profiles stops working and throws a 0x40000024 no data error when finalizing. User mode sampling seems to have no issue.
The applications I'm trying to test work with older versions of vtune and cpu without a problem. And I've already updated the ME/chipset/serialio driver to the latest version listed on motherboard's vendor site(gigabyte Z590M gamingX). Any idea about what's the cause of this? Thanks.
0 포인트
29 응답
AthiraM_Intel
중재자
15,933 조회수
Make sure that VTune self check script is running fine to validate that appropriate drivers are installed and the system is set up properly to collect performance data. See whether its working fine and share the log.
The self-check file for windows “vtune-self-checker.bat” and for linux “vtune-self-checker.sh” will be there in the <vtune-installation-directory>/bin64 folder if the VTune installation was done successfully.
Could you please let us know which version of vtune you are using?
Also share the OS details.
0 포인트
AthiraM_Intel
중재자
15,872 조회수
We haven't heard back from you. Could you please give us an update ?
0 포인트
111alan
초보자
15,863 조회수
Sorry for the delayed response. Currently the platform is at another place, but I've confirmed that Cascade lake platform has no issue with new vtune(2021.2) on the same system. I'll ask my friend to check on Cypress Cove platform again for me. Thank you for your suggestion, I'll reply again when I have the results.
0 포인트
AthiraM_Intel
중재자
15,829 조회수
Thanks for the update. We will wait for your results.
0 포인트
AthiraM_Intel
중재자
15,769 조회수
Did you get the results? Could you please give us an update?
0 포인트
111alan
초보자
15,738 조회수
Just assembled the Icelake-SP platform. Seems that no luck as well. I ran the self test and there's quite a few errors and warnings. Attached are the log file and the output of the script.
Also I've installed and re-installed everything from Supermicro's motherboard driver page. The OS version is Windows10 20H2, vtune version is still 2021.2. Wondering what's not right here.
Thank you for your attention.
0 포인트
AthiraM_Intel
중재자
15,691 조회수
Thanks for sharing the result.
Could you please install the latest version of Vtune (2021.3.0) and check whether the issue still persists.
You can download the latest vtune from the below link:
https://software.intel.com/content/www/us/en/develop/articles/oneapi-standalone-components.html#vtune
If the issue still persists please let us know.
0 포인트
111alan
초보자
15,679 조회수
Just tried it, most of the errors are gone, but "HW event-based analysis (counting mode)" still fails. The "Microarchitecture Exploration" preset can finally finish properly, but there are still some problems I encountered:
1. "MEM_LOAD_RETIRED.L1_HIT" seems to be missing in the final result chart.
2. If I add more event counters(namely MEM_LOAD_RETIRED.L2_MISS and BR_INST_RETIRED.ALL_BRANCHES) into the microarchitecture exploration preset, the "microarchitecture exploration" summary page will disappear. I remember in the old version adding more counters won't disable any feature.
3. A gui bug shown below.
Thank you.
0 포인트
111alan
초보자
15,653 조회수
My friend just tested it on Rocketlake. Also some failures  detected, mainly no-data error. Here are the log and output.
0 포인트
AthiraM_Intel
중재자
15,648 조회수
We are checking on it internally, will get back to you soon.
0 포인트
Kevin_O_Intel1
15,620 조회수
Can you run vtune_self_checker.sh >& log
And attach the log
0 포인트
111alan
초보자
15,596 조회수
Is this log only acquirable in linux version? If so I'll install a Ubuntu and try this. Thanks.
0 포인트
matthias-vigelius
초급자
15,613 조회수
not the original poster but I'm having the same problem. I'm running the latest version 2021.3 on i7-1165g7 (tiger lake).
Please find attached the log.
Thanks heaps!
0 포인트
Kevin_O_Intel1
15,582 조회수
Can you verify you are using vtune 2021 update 3.... this is the latest version of vtune and should support your processor
0 포인트
matthias-vigelius
초급자
15,575 조회수
Hi Kevin_O_Intel1,
I'm using version 2021.3.0, build 616728.
Thanks!
0 포인트
Kevin_O_Intel1
15,565 조회수
You can run vtune-self-checker.bat on windows
0 포인트
111alan
초보자
15,564 조회수
Then I already did, and the logs and script outputs are attached above.
0 포인트
Kevin_O_Intel1
15,468 조회수
Can you zip and attach C:\Users\vigel\AppData\Local\Temp\vtune-tmp-vigel\self-checker-2021.05.25_14.13.45\
0 포인트
111alan
초보자
15,460 조회수
Here, there's an additional txt inside for script outputs. Thanks.
0 포인트
matthias-vigelius
초급자
15,427 조회수
Here you go.. Thanks for taking care of it!
0 포인트
응답
