Arria 10 GX FPGA
Error (11176): Alt_sld_fab_0.alt_sld_fab_0: add_instance: Can't create component type altera_sld_agent_endpoint_tieoff
Info (11172): invoked from within
Info (11172): "add_instance sldfabric_t0 altera_sld_agent_endpoint_tieoff"
Info (11172): ("eval" body line 32)
Info (11172): "eval $tcl"
Info (11172): (procedure "compose" line 36)
Info (11172): "compose"
Info (11172): "interp eval $slave {
Info (11172): Compose
Info (11172): }"
Error (11176): Alt_sld_fab_0.alt_sld_fab_0.alt_sld_fab_0.auto_signaltap_add_afu.clock: auto_signaltap_add_afu.clock must be connected to a clock output
Info (11172): ***************************************************************
Error (11176): Error opening ../../../build/qdb/_compiler/afu_default/_flat/19.2.0/partitioned/1/.temp/sld_fabrics/ipgen/alt_sld_fab_0/alt_sld_fab_0.ip.
I have resolved the issue. Please close the request service. Thank you!!!!
Hi @khyam
I found a case with similar error although the user seems to resolve the issue on their own.
May I know what kind of design that are you using to run the compilation? Have you try to run an example design that is available in our Intel website?
Richard Tan
p/s: If any answer from the community or Intel support are helpful, please feel free to give Kudos.
I used sample example nlb_mode_0_stp, its has signal tap file(.stp). I used mmlink utility of OPAE2.0 for debugging the Arria 10 GX and D5005 PAC card with system console and quartus signal tap tool. The AFU with .stp file compiled successfully and I can see the signal tap instance but receive the following error when trying to acquire data.
"Error (261005): can't find the instance. Download a design with SRAM Object File Containing this instance."
When I used my own design, that is integrated with Xeon host processor in OPAE Platform. without Signal tap (.stp) file, it compiled successfully, but when i try to add .stp file instance in my design, I am getting below error.
Yup looked the post you provide, but he didn't explained, how he resolve the issue.
Hi @khyam
Could you try to cross check with the user guide flow in step 1 & step 2 and compile the design again?
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-qpp-debug.pdf#page=24
Let me know how it goes.
Richard Tan
Hi @khyam
I am glad that you are able to solve the issue. Would you mind to share with us the root cause and the solution to solve this issue?
This may helps those who come across this issue.
Richard Tan
Since the question has been addressed, I will now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Richard Tan
Solution:
Add below command to the afu.qsf file to set stp file
set_global_assignment -name VERILOG_MACRO "INCLUDE_REMOTE_STP"
then run the design using $run.sh command
or
Add this line to filelist.txt file.
+define+INCLUDE_REMOTE_STP
Then build the design using following command
afu_synth_setup --source filelist.txt build/stp
So, It will add signal tap host instance in the design.
good sharing
![](/skins/images/60C00329A4E2CF12858AE4B78C36FA61/responsive_peak/images/icon_anonymous_message.png)
