Is there any ways to obtain the amount of register and logic consumed from running inference on the Arria 10 PAC? I am trying to get the sof/pof report like those generated on Quartus when running synthesis.
Does programming a bitstream on the Arria 10 PAC generate a report?
Thank you.
You can find the details from the following:
/build_synth/build/output_files/afu_default.fit.rpt
Can I perform this on DevCloud Edge as well? If so, what is the path to the rpt file?
Thank you.
Topic Options
