Edge Software Catalog
472 Discussions
Error in the installation of the software edge_insights_for_amr
Eduardo5
Débutant
954 Visites
eduardo@eduardo-CM11EBV716W:~/Descargas/edge_insights_for_amr$ ./edgesoftware install
Failed to create log file. [Errno 13] Permission denied: '/var/log/esb-cli/Edge_Insights_for_Autonomous_Mobile_Robots_2021.4.1/output.log
Étiquettes (1)
0 Compliments
1 Répondre
Sahira_Intel
Modérateur
941 Visites
Hi Eduardo5,
Did you change the permission on the executable installation file? Also, run the installation command as sudo. Try to re install using the following commands while you are in the edge_insights_for_amr directory:
chmod 775 edgesoftware
sudo ./edgesoftware install
Please let me know if you have any other questions.
Sincerely,
Sahira
0 Compliments
Répondre
