Edge Software Catalog
The Edge Software Catalog community is read-only. For support, please visit the Open Edge Platform (https://github.com/open-edge-platform) GitHub organization and post your question in the relevant repository’s Issues section.
492 Discussions
Error in the installation of the software edge_insights_for_amr
Eduardo5
eduardo@eduardo-CM11EBV716W:~/Descargas/edge_insights_for_amr$ ./edgesoftware install
Failed to create log file. [Errno 13] Permission denied: '/var/log/esb-cli/Edge_Insights_for_Autonomous_Mobile_Robots_2021.4.1/output.log
Sahira_Intel
Hi Eduardo5,
Did you change the permission on the executable installation file? Also, run the installation command as sudo. Try to re install using the following commands while you are in the edge_insights_for_amr directory:
chmod 775 edgesoftware
sudo ./edgesoftware install
Please let me know if you have any other questions.
Sincerely,
Sahira
