- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
The Pin Interface section of the Intel® Ethernet Controller X550 Datasheet lists VCCA pins as 1.0V power pins. Except from this, the pins are not mentioned at all in the document. The Electrical/Mechanical Specification section only describes 4 voltage rails: VCC3P3, VCC2P1, VCC1P2, VCC0P83. From the reference schematics it looks like these pins should only connect to decoupling capacitors and no voltage source. Is this correct? Where is it documented?
Terje
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello, Terje :
We apologize for the delay to give you an update.
Based on the information stated in Seccion 2.11, on page 44 of the https://www.intel.com/content/dam/www/public/us/en/documents/datasheets/ethernet-x550-datasheet.pdf Intel(R) Ethernet Controller X550 Datasheet document # 333369, the only VVCA difference between the X550-AT2 and X550-BT2 is the balls associated to it.
Due to this fact, the information that may help you is stated in section 9.1, on page 11 of the https://cdrdv2.intel.com/v1/dl/getContent/514722 Intel(R) X540/X550-BT2 (Sageville) Ethernet Controllers Dual Layout Design Considerations and Guidelines document # 514722.
This document is accessible when you are logged into your Resource & Design Center (RDC) privileged account. It can be requested by filling out the https://www.intel.com/content/www/us/en/forms/design/contact-support.html RDC Account Support form.
We hope that this information may help you.
Carlos_A.
Link kopiert
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello, Terje :
In order to be on the same page, could you please tell us if this request is related to a technical problem? in case that your answer is affirmative please give us a detailed description.
Waiting for your reply to this question.
Carlos_A.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
No. I just want to make sure we get our design right so that I don't have to come back to this forum with a problem 3 months from now .
Terje
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi Carlos,
Have you been able to dig up an answer to my question?
Terje
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello, Terje :
Carlos_A.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Thank you very much! That was exactly the type of statement I couldn't find in any of the X550 documentation. Without any plans of supporting dual controllers, the document you point to did not seem relevant.
If you have a system for collecting suggestions for improvements of documentation, I would suggest that you submit this in order to get all relevant issues documented where it should..
Thanks again!
Terje
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
