Hi Bz1977,
I am glad that your issue is already solved. If there is no other issue regarding this matter, I will be closing this issue/thread.
This is almost always caused by bad Ethernet cable(s). Have you tried replacing the cable(s)?
Have you tried a different port on your router/switch?
To get more information regarding your Windows configuration, please download and run the Intel System Support Utility for Windows. When you start the tool, select Everything and then click on Scan. Once it completes the scan process, click on Next and then Save. Pick a name for the text file to create and click on Save to create it. You can then close the app. Finally, open a response post here and then, using the Drag and drop here or browse files to attach dialog (below the edit box for the body of your response post), upload and attach this text file to the response post.
Hi Bz1977,
