FPGA Intellectual Property
6672 Discussions
Avalon-ST Test Pattern Generator and Checker
I designed my custom Avalon-ST peripheral and would like to test in on my FPGA. I found Altera's Avalon-ST Test Pattern Generator and Checker IPs and would like to use them in my tests. I try to generate packets(!), but nothing happens. At the end I connected Generator with Checker direct and looked with SignalTap on my Avalon-ST bus, but nothing was there.
For initialization I use Altera's API commands in this order:
data_source_reset(0x5000880) ;
data_sink_reset(0x5000860) ;
usleep(1700000) ;
data_sink_init(0x5000860) ;
data_sink_set_enable(0x5000860, 0x1) ;
usleep(1700000) ;
data_source_init(0x5000880, 0x5000890) ;
data_source_set_enable(0x5000880, 0x1) ;
usleep(1700000) ;
The addresses are defined in system.h:
# define SINK_0_BASE 0x5000860
# define SOURCE_0_COMMAND_BASE 0x5000890
# define SOURCE_0_CSR_BASE 0x5000880
What am I doing wrong? How should I start the packet generator? This problem tortures me the whole weekend.
Linas
I solved it:
data_sink_init(SINK_0_BASE);
data_sink_set_enable(SINK_0_BASE, 1);
data_source_set_enable(SOURCE_0_CSR_BASE, 1);
data_source_send_data(SOURCE_0_COMMAND_BASE, 1, 64, 0x03, 0, 0);
With these commands I am able to generate the needed packets.
