FPGA Intellectual Property
Comunicados
6673 Discussões
Cannot open the project. Quartus Prime Settings file contains one or more errors
ymiler
Funcionário
3.212 Visualizações
Hi
When I try to open <projet name>.qpf file - I got the mesage
"Cannot open the project. Quartus Prime Settings file contains one or more errors"
According to your recommendtion - (ID: 125080)
"Correct the QSF syntax errors described in the error messages, and then open the project"
But, I dont know what are the syntax errors - How can I know which lines/errors the Quartus found ?
Is there any log file ?
Yishay
9 Respostas
sstrell
Colaborador honorário III
3.180 Visualizações
You could post the .qsf file here to let others help or just create a new Quartus project from scratch to create a new .qsf.
ymiler
Funcionário
3.163 Visualizações
Hi
This problem occur for time to time ,
I prefer a log from quartus that indicate which & what is the sytanx error - If we dont have this option the other way is guess what is the problem
Yishay
sstrell
3.130 Visualizações
Just post the file here.  I'm sure myself (or somebody) will be able to see the problem right away.  If Quartus can't read the .qsf file and says just that, you're not going to get more detailed info.
RichardTanSY_Altera
3.108 Visualizações
Hi @ymiler
You may need to share the design files so we can take a look for what goes wrong.
Else, I recommend to create a new project per sstreell suggestion, and compare it with the one with error.
Richard Tan
p/s: If any answer from the community or Intel support are helpful, please feel free to give Kudos.
ymiler
Funcionário
3.104 Visualizações
I found the problem in my QSF file  by myself,
But it's best parctice that Quartus will create log for easy inqiry
Yishay
RichardTanSY_Altera
3.092 Visualizações
Hi @ymiler
Good to know that you are able to found the solution.
I will filed an enhancement request regarding this feedback such that the Quartus will report out a more useful message that show where goes wrong, instead of a generic messages.
Richard Tan
RichardTanSY_Altera
3.090 Visualizações
Hi @ymiler
Could you help to share the screenshot and a simplified design files with the error duplicable?
I might need this information to file a request for the engineering team.
Richard Tan
ymiler
Funcionário
3.089 Visualizações
It was simply syntax error -I had enviorment variable  that I missed to define
Yiahay
RichardTanSY_Altera
3.085 Visualizações
Could you help to share the line that you missed to define in .qsf? So I get a grasp of what it look like.
Richard Tan
Responder
