FPGA Intellectual Property
6669 討論
Cyclone V: Meeting timing with HMC and DDR3-800?
jrrguzman
新貢獻者 I
1,523 檢視
I'm using a Cyclone V-SE and trying to implement a HMC targetting a DDR3-800. After plugging in all the values from the vendor datasheet and running the whole compilation flow I can't get the design to meet timing (DDR Read Capture hold constraint fails miserably).
First of all I want to know if this is actually possible. If so, what are the main parameters used in the Read Capture setup/hold analysis?
Kind regards
0 積分
3 回應
sstrell
榮譽貢獻者 III
1,199 檢視
Just to make sure your device can support this, fill out the spec estimator and check the results:
https://www.intel.com/content/www/us/en/programmable/support/support-resources/support-centers/external-memory-interfaces-support/emif.html
Since you're using an SoC device, are you using the HPS hard controller, an FPGA hard controller, or a soft controller?
Are you running your user logic half-rate or quarter rate (if supported for your particular configuration)?
#iwork4intel
jrrguzman
新貢獻者 I
1,199 檢視
Hi @sstrell​
I've checked the link and in principle I should be able to run DDR3-800 (400MHz)
I've got the HPS running at DDR3-800 without a problem. However I also want to use the FPGA HMC and drive another DDR3-800 memory chip. However, after pluggin in the values from the manufacturer, the Read Capture hold analysis has a 7 ps violation.
In principle, the HMC for Cyclone V only allows full data rate on the user logic. I've included the current configuration (maybe you can spot what's the issue)
Cheers.
KhaiChein_Y_Intel
1,199 檢視
Can you provide the design.qar for investigation?
回覆
