FPGA Intellectual Property
DMA without nios
i am thinking that how to use a dma without nios.
it seems i shoud write a dma controller by myself.
does any one has done the same thing before?
or any one can provide me some examples?
thanks
Do you mean you have a system without any CPU and need to transfer data to/from memory? What's the actual use of such a system?
You can either write your own DMA, or create a component that's able to control the registers of an existing DMA.
i just want to get datas form ssram throug dma,btw,that just is a homework.
so, now i am thinking can i use spoc-builder to generate one.
Yes SOPC builder is the way to go. But how will you put the data into your ssram in the first place?
:)i just load a image into ssram(de2-70 board through panel-tool) , i want get datas out ,then i think of dma ,meantime i saw a paper in the internet,it uses this mather throug dma do the same thing and also shows a module image without source code (those in/outputs are belowe ) . but in the paper it seems the dma module is writed by hand and made by fifo megawizard ,so i wonder if i can make one by sopc builder , aha...:), just a weird idea .
iCLK
iFIFO_RST_n
iRD1_FIFO_RD_CLK
iRD1_FIFO_RD_REQ
iRD2_FIFO_RD_CLK
iRD2_FIFO_RD_REQ
iRD3_FIFO_RD_CLK
iRD3_FIFO_RD_REQ
iRD4_FIFO_RD_CLK
iRD4_FIFO_RD_REQ
iRD5_FIFO_RD_CLK
iRD5_FIFO_RD_REQ
iRST_n
iTRIGGER
iWR1_FIFO_WR_CLK
iWR1_FIFO_WR_REQ
iWR1_FIFO_DATA_IN[31..0]
iSSRAM_READDATA[31..0]
oRD1_FIFO_RD_EMPTY
oRD2_FIFO_RD_EMPTY
oRD3_FIFO_RD_EMPTY
oRD4_FIFO_RD_EMPTY
oRD5_FIFO_RD_EMPTY
oSSRAM_READ
oSSRAM_WRITE
oRD1_FIFO_DATA_OUT[31..0]
oRD2_FIFO_DATA_OUT[31..0]
oRD3_FIFO_DATA_OUT[31..0]
oRD4_FIFO_DATA_OUT[31..0]
oRD5_FIFO_DATA_OUT[31..0]
oSSRAM_ADDRESS[18..0]
oSSRAM_WRITEDATA[31..0]
I don't know how the panel tool works, but you'll probably need a SOPC project with either a Nios CPU or a jtag-to-avalon debug module for it to access the SRAM. So in this case you'd better use SOPC builder and make a component with an Avalon master interface, to be able to share the SRAM between JTAG and your DMA.
well.. this is a stupid question, but i wanna ask anyway..
So you could actually create something using SOPC without implementing a NIOS 2 processor? I thought the whole purpose of using SOPC is to implement a design with a NIOS 2?
Michael
--- Quote Start ---
--- Quote End ---
Its not a stupid question. All the documentation relating to SOPC/Qsys generally talk about NIOS II systems. However, all you really need is an Avalon-MM bus master. The NIOS II just happens to be one type of master.
I rarely use the NIOS II processor. I use the JTAG-to-Avalon-MM bridge for debugging, and then have other processor-to-Avalon-MM master designs for accessing components inside the FPGA.
Cheers,
Dave
--- Quote Start ---
Michael
--- Quote End ---
The next generation tool called "Qsys" was specifically named that to try to break the perception that you can't use SOPC Builder without Nios II. Nios II is a software core processor, SOPC Builder and Qsys are system integration tools. The only thing the SOPC Builder/Qsys have in common in common with Nios II is support for Avalon memory mapped interfaces.
