FPGA Intellectual Property
DSP IP problem
I am trying to simulate a low pass filter using DSP megafunction in Modelsim.
I am also using licensed Quartus full version to generate the IP.
The error I am getting is:
instantiation of 'lpf_1_ast' failed. the design unit was not found.
# region: /test_lpf/inst
Now, I am working in verilog i.e, the main instantiation file is "lpf_1.v".
I have seen that FIR filter IP generates many files including "lpf_1_ast.vhd" but not "lpf_1_ast.v".
Kindly, tell me how can I solve the problem ?
A quick reply will be greatly appreciated.
Thank you !!!
I have also tried to compile the LPF_1_ast.vhd file, it is showing the error:
error:library auk_dspip_lib not found.
I have tried to search the library but could not find it.
After I synthesized the module in Quartus, by looking at the netlist viewer, it seems that the LPF_1 has got generated properly.
Thank you !!
