FPGA Intellectual Property
6670 Discussions
Documentation on MAX10 fiftyfivenm_rublock command
SWinc
I am looking for the documentation that describes the protocol used to update CFM0 / CFM1&CFM2. UG-M10CONFIG mentions the fiftyfivenm_rublock, but I can not seem to find any documentation that describes the correct sequence of events to update the configuration memory.
Any help would be greatly appreciated.
Thank you,
Sam
Nooraini_Y_Intel
Hi Sam @SWinc​,
In order to update the CFM0 and CFM1/2 memory block, you need to use the On-Chip flash IP. The fiftyfivenm_rublock does not function to access CFM or UFM memory block in the MAX 10. You can refer to the MAX 10 User Flash Memory user guide for the details on the On-Chip Flash IP protocol.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/ug_m10_ufm.pdf
Nooraini
SWinc
I am still missing something. What is the purpose of the fiftyfivenm_rublock block (which is mentioned in https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/ug_m10_config.pdf, specifically "2.2.1. Remote System Upgrade" which mentions the rublock as the method of updating through User Logic) ?
Thank you for your reply
Nooraini_Y_Intel
Hi Sam @SWinc (Customer)​,
The fiftyfivenm_rublock is use in the Dual Boot IP to perform configuration (to switch) between image 0 and image 1 store in the CFM0 and CFM1/2 memory block respectively. You can refer to figure 3 under chapter "2.2.1. Remote System Upgrade" which only shows the process to switch between image 0 and image 1.
Nooraini
jozephka99
New Contributor II
So, we have to use this block if we want to RSU through user logic. But there is no documentation about this. How can we exactly build a user logic to perform RSU. Also this fiftyfivenm_rublock is in verilog. How can we implement this into VHDL.
