FPGA Intellectual Property
6667 Discussions
FFT 8.0 for beginner
Hello everybody,
I am totally new at FPGA-programming (Cyclone III Starter) and especially in understanding the Altera-FFT-core.
I read the user guide and half of the FFT-threads, but my simulation does not work :(
At first I tried a 64-point burst FFT to see how everything works, later I want to use a 4096-point FFT to transform a signal from an ADC-board.
I generated a random input signal (only real, imag and exp = 0), I set the sink_sop, sink_eop, source_ready and reset_n as shown in the FFT user guide. But there is no source_sop the whole time?! I can imagine that the source_real is always 0, because of the missing source_sop...
But why does not assert the source_sop? EDIT: The source_valid shuold assert before the source_sop can assert, OK! But why doesn't the source_valid assert? :confused:
I think it could be a mistake of beginners :rolleyes:
Thanks for your help!
Ok, I think I didn't simulate long enough.
Now I got results, which make me happier :D
Could somebody watch to my screenshot and perhaps tell me, why the sop, eop get managed wrong?!
it probably has to do with the source_error codes that are popping up.
check how many packets are making it to the FFT since your sink_ready pin is asserted then deasserted, etc.
How do you easily enter some meaningful signal to the FFT for simulation?
