FPGA Intellectual Property
6670 Discussions
How can I use clock signal
I am implementing Physical layer of a base band transmitter in simulink using DSP builder blocks. How can I use the clock signal in my design?
I need it for implementing manchester encoder.
G Shah
you need to connect a clock to all of the clock inputs.
Thanks for the reply but the problem remains;
All the registered DSP builder blocks uses an internal clock. I can just instantialte the clock block, I cannot connect it to any other blcok.
On the basis of the registered dsp blocks (which uses the internal clock) I have developed my logic. Now I want to connect the same clock to a non registered blcok.
Kindly let me know if any body know it.
regards
shah
Hi!
I also had a problem with the usage of the clock signal in DSP Builder.
I tried to implement a clock recovery for a transceiver and I finally gave it up.
I know how to set a clock, how to derive it or how to use a pll, but I think it is not possible with the DSP Builder to have the clock as "signal line"
So if you have any clues I would be glad to hear them.
I now implement basic logic in quartus II and import more complex funktions then from generated vhd files from DSP Builder.
