FPGA Intellectual Property
6670 Discussions
Issue with PCIe HIP(A10) Gen3 model behavior in simulations with serial interface
RamaMohan
We are facing an issue in simualtions, with the data transmitted from PCIe hard-IP model during initialization while switching from Gen1 to Gen3 Speed. The model being used is the one for A10 FPGA device. Here’s the issue:
After moving Recovery.Speed state and sending TS ordered set, HIP is sending unknown symbols on Tx with HiZ on the lines.
The said behavior is seen repeatedly for a long time before HIP Tx enters electrical Idle.
The simulation has enabled fast_sims in serial mode.
Appreciate help/suggestions
RamaMohan
RamaMohan
Hi Nathan, Appreciate if you can get this issue reproduced and get the fix ASAP. This is really blocking us. Thanks, RamaMohan
Nathan_R_Intel
​Hie  RamaMohan,
I believe my last update did not get through.
I tried with VCS and still unable to reproduce the issue. Hence, without your RP BFM, I am unable to replicate the failure and de bug further.
Nathan
