FPGA Intellectual Property
6673 Discussions
Issues programming encryption (.EKP) file to FPGA
Hi
Is there a way to check whether or not an FPGA has had it encryption key programmed into the device?
Maybe it can send a message to Quartus or set an output pin as a flag for example.
This would be useful because I'm struggling to program encryption keys into a batch of FPGA and just need to confirm there's no key already programmed.
FPGA is Stratix II EP2SGX30 and I'm using an Ethernet Blaster II.
Any help appreciated, thanks.
