FPGA Intellectual Property
6669 Discussions
Linux driver for AVMM Arria10 PCIe is deprecated
Nyah
Hello!
i'am try build drivers from https://community.intel.com/t5/FPGA-Wiki/Reference-Design-Gen3x8-AVMM-DMA-Arria-10/ta-p/735904
I have error with "struct timeval".
Makefile is fixed ccflags-y += "-Wno-date-time", but error is still happened.
target PC: Ubuntu 20.04 ;linux 5.11
Thanks!
rm -rf *.o *~ core .depend .*.cmd *.ko *.mod.c .tmp_versions *.symvers *.order
make -C /lib/modules/5.11.0-27-generic/build M=/home/pcuser/projects/avmm_dma_linux
make[1]: Entering directory '/usr/src/linux-headers-5.11.0-27-generic'
  CC [M]  /home/pcuser/projects//avmm_dma_linux/altera_dma.o
In file included from /home/pcuser/projects//avmm_dma_linux/altera_dma.c:14:
/home/pcuser/projects//avmm_dma_linux/altera_dma_cmd.h:49:20: error: field ‘write_time’ has incomplete type
   49 |     struct timeval write_time;
/home/pcuser/projects//avmm_dma_linux/altera_dma_cmd.h:50:20: error: field ‘read_time’ has incomplete type
   50 |     struct timeval read_time;
/home/pcuser/projects//avmm_dma_linux/altera_dma_cmd.h:51:20: error: field ‘simul_time’ has incomplete type
   51 |     struct timeval simul_time;
/home/pcuser/projects//avmm_dma_linux/altera_dma.c: In function ‘init_rp_mem’:
/home/pcuser/projects//avmm_dma_linux/altera_dma.c:272:9: warning: unused variable ‘increment_value’ [-Wunused-variable]
  272 |     u32 increment_value = 0;
/home/pcuser/projects//avmm_dma_linux/altera_dma.c: In function ‘rp_ep_compare’:
/home/pcuser/projects//avmm_dma_linux/altera_dma.c:311:3: warning: this ‘else’ clause does not guard... [-Wmisleading-indentation]
  311 |   else
/home/pcuser/projects//avmm_dma_linux/altera_dma.c:313:8: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘else’
  313 |        printk(KERN_DEBUG "ep_tmp = %08x\n", ep_tmp);
/home/pcuser/projects//avmm_dma_linux/altera_dma.c:287:9: warning: unused variable ‘count’ [-Wunused-variable]
  287 |     u32 count = 1;
/home/pcuser/projects//avmm_dma_linux/altera_dma.c:286:12: warning: unused variable ‘rp_tmp’ [-Wunused-variable]
  286 |     u32 j, rp_tmp, ep_tmp;
/home/pcuser/projects//avmm_dma_linux/altera_dma.c: In function ‘dma_test’:
/home/pcuser/projects//avmm_dma_linux/altera_dma.c:368:20: error: storage size of ‘tv1’ isn’t known
  368 |     struct timeval tv1;
/home/pcuser/projects//avmm_dma_linux/altera_dma.c:369:20: error: storage size of ‘tv2’ isn’t known
  369 |     struct timeval tv2;
/home/pcuser/projects//avmm_dma_linux/altera_dma.c:370:20: error: storage size of ‘diff’ isn’t known
  370 |     struct timeval diff;
/home/pcuser/projects//avmm_dma_linux/altera_dma.c:436:2: error: implicit declaration of function ‘do_gettimeofday’; did you mean ‘do_settimeofday64’? [-Werror=implicit-function-declaration]
  436 |  do_gettimeofday(&tv1);
      |  do_settimeofday64
/home/pcuser/projects//avmm_dma_linux/altera_dma.c:370:20: warning: unused variable ‘diff’ [-Wunused-variable]
/home/pcuser/projects//avmm_dma_linux/altera_dma.c:369:20: warning: unused variable ‘tv2’ [-Wunused-variable]
/home/pcuser/projects//avmm_dma_linux/altera_dma.c:368:20: warning: unused variable ‘tv1’ [-Wunused-variable]
/home/pcuser/projects//avmm_dma_linux/altera_dma.c:362:13: warning: unused variable ‘ep_tmp’ [-Wunused-variable]
  362 | u32 rp_tmp, ep_tmp;
/home/pcuser/projects//avmm_dma_linux/altera_dma.c:362:5: warning: unused variable ‘rp_tmp’ [-Wunused-variable]
/home/pcuser/projects//avmm_dma_linux/altera_dma.c:361:12: warning: unused variable ‘j’ [-Wunused-variable]
  361 |     int i, j;
/home/pcuser/projects//avmm_dma_linux/altera_dma.c:360:63: warning: unused variable ‘simul_write_count’ [-Wunused-variable]
  360 |     int loop_count = 0, num_loop_count = 1, simul_read_count, simul_write_count;
/home/pcuser/projects//avmm_dma_linux/altera_dma.c:360:45: warning: unused variable ‘simul_read_count’ [-Wunused-variable]
/home/pcuser/projects//avmm_dma_linux/altera_dma.c:360:25: warning: unused variable ‘num_loop_count’ [-Wunused-variable]
/home/pcuser/projects//avmm_dma_linux/altera_dma.c:360:9: warning: unused variable ‘loop_count’ [-Wunused-variable]
/home/pcuser/projects//avmm_dma_linux/altera_dma.c: In function ‘diff_timeval’:
/home/pcuser/projects//avmm_dma_linux/altera_dma.c:937:24: error: dereferencing pointer to incomplete type ‘struct timeval’
  937 |     long int diff = (t2->tv_usec + 1000000 * t2->tv_sec) - (t1->tv_usec + 1000000 * t1->tv_sec);
In file included from /home/pcuser/projects//avmm_dma_linux/altera_dma.c:15:
/home/pcuser/projects//avmm_dma_linux/altera_dma.c: At top level:
/home/pcuser/projects//avmm_dma_linux/altera_dma.h:171:12: warning: ‘rp_compare’ declared ‘static’ but never defined [-Wunused-function]
  171 | static int rp_compare(u8 *virt_addr1, u8 *virt_addr2, u32 num_dwords);
/home/pcuser/projects//avmm_dma_linux/altera_dma.c: In function ‘altera_dma_ioctl’:
/home/pcuser/projects//avmm_dma_linux/altera_dma.c:25:13: warning: this statement may fall through [-Wimplicit-fallthrough=]
   25 |             dma_test(bk_ptr, bk_ptr->pci_dev);
/home/pcuser/projects//avmm_dma_linux/altera_dma.c:26:9: note: here
   26 |         case ALTERA_CMD_WAIT_DMA:
cc1: some warnings being treated as errors
make[2]: *** [scripts/Makefile.build:287: /home/pcuser/projects//avmm_dma_linux/altera_dma.o] Error 1
make[1]: *** [Makefile:1848: /home/pcuser/projects//avmm_dma_linux] Error 2
make[1]: Leaving directory '/usr/src/linux-headers-5.11.0-27-generic'
make: *** [Makefile:11: all] Error 2
insmod: ERROR: could not load module ./altera_dma.ko: No such file or directory
Harris
It's an OS/compiler compatibility issue. The original driver is compiled on Centos, and it is just for customer's reference. We don't provide support to PCIe driver. I suggest you try to find the solution from the internet with search engine. Thanks.
BR/Harris
