FPGA Intellectual Property
6665 Discusiones
Multiple packets in 256-bit PCIE endpoint
Colaborador Distinguido II
1.009 Vistas
I want to use stratix V 256-bit pcie end point in my design. Is it possible that the endpoint outputs 2 mem read/write TLPs in the same cycle???
In other words, In 256-bit end point we have a two bit st_avalon_sop and st_avalon_eop signal. Is it possible that the endpoint asserts both sop bits or both eop bits in the same cycle?
Since a read tlp only occupy 3 DWs so should I need to implement the support to handle two memory read/write TLPs in the same cycle
Thanks in advance
0 kudos
0 Respuestas
Responder
