FPGA Intellectual Property
6656 Discussions
PCIe IO BAR's limited to "Legacy Endpoints"
I am looking to define an EP with a BAR defined as IO instead of memory inorder to test the IO / CNFG PCI ordering rules .
I thought it would be as easy as going into an existing design and re-defining the BAR type ... It appears the IO BAR type is only supported by "Legacy Endpoints" .
Does anyone know why this is or how to get around it ?
Thanks, Bob.
IO style endpoints aren't really supported in PCIe. They only exist so that legacy PCI cards can be attached via a PCIe to PCI bridge. I wouldn't be at all surprised to find out they don't work. I wouldn't be upset about it either. It's basically legacy garbage that should be ignored in a modern design.
--- Quote Start ---
--- Quote End ---
Thanks Galfonz.
I'm not particularly interested in IO and understand the point you make but I am interested in testing ordering rules for IO and Configuration Writes / Reads per the specified rules since IO and Configuration are handled differently ... Since IO and Configuration are treated the same with respect to ordering , I thought IO would be easier to implement.
If it is't easy to implement with the hard PCIe IP I have access to ... then I will look to the Keysight and LeCroy Exerciser cards that I have access to.
It's definitely going to be easier to use something that will generate the kind of traffic you are interested in and a monitor to view what the responses are than it would be to implement something with an FPGA, hard IP or soft.
