I use hardcore PCIe IP in Cyclone V device as endpoint. after link up, I try to write to endpoint memory through root complex controller in processor. But there is no signal coming out of avalon st rx interface. the processor returns "completion time out error". After the error occurs, lspci is not working. But in FPGA, link LTSSM is in L0. rx_st_ready, tx_st_ready are asserted. Please suggest possible root cause of the error to debug further. Thanks, Aj.Link Copied
--- Quote Start --- Hi, I use hardcore PCIe IP in Cyclone V device as endpoint. after link up, I try to write to endpoint memory through root complex controller in processor. But there is no signal coming out of avalon st rx interface. the processor returns "completion time out error". After the error occurs, lspci is not working. But in FPGA, link LTSSM is in L0. rx_st_ready, tx_st_ready are asserted. Please suggest possible root cause of the error to debug further. Thanks, Aj. --- Quote End --- Hello Aj, I worked on the same thing. I was able to write to my endpoint. Please list all your steps and settings in detail, maybe minor issue in configuration?
