FPGA Intellectual Property
6669 Discussions
Problems with the CVI and CVO Sof-Signals
I really need help. I have a simple VideoProcessing Modul. I hav a CVI --> ChromaResampler --> CVO, and a Cylone IV E
I have different clocks for the PixelClock-Input an the PixelClock Output. Both are 74.25MHz but the Input PixelClock is an external Clock, and the Output-Pixel_Clock is an PLL-generatet Pixel-Clock. I need this PLL - Clock because the other clock has Jitter/Wander on it.
I don't have a NIOS in my System. I connected the sof_input and the sof_input_locked Signal with the output_sof_locked and the outpu_sof-Signal.
I changed some lines in the control-vhdl-Code in the IP-File.
In this File "alt_vipcti120_Vid2IS_control" I changed
Line 143 assign enable = 1'b1;
Line 113 - 121
genlock_enable <= 1'b1;
interrupt_enable <= 2'b00;
enable_reg <= 1'b1;
status_update_int_reg <= 1'b0;
stable_int_reg <= 1'b0;
sof_sample <= 14'd2194;
sof_subsample <= 2'd1;
sof_line <= 13'd1124;
refclk_divider_value <= 14'd1;
On the CVO File "alt_vipitc120_IS2Vid_control"
I changed Line 94 - 99
if (rst) begin
genlock_enable_reg <= 2'b1;
interrupt_enable <= 2'b1;
enable_reg <= 1'b1;
genlocked_int_reg <= 1'b0;
and Line 117
This works for about 3 Minutes, in this Time I can see a stable picture, but then I get an CVI-FIFO Overflow and my analyzer can still detect the right Videoformat, but I only get a black picture. After a few Minutes the picture startet to change the colour.
If I use my Video-Input_pixel-Clock as my VideoOutput_Pixel-Clock I alwys get a stable picture.
Please tell me, what can I do against this overflow? What can I do to synchonize the Input and the Output without the same Pixel_clock.
Can anybody help me?
Thanx Anja
