FPGA Intellectual Property
6670 Discussions
Quartus DPRAM interface with Nios
I have defined a system with the following:
- qsys system with Nios
- tcl script to export avalon signals to the top module
- two quartus DPRAM components - dpram0, dpram1 (external to Nios)
- port a of dprams connected to avalon export (direct Nios write/read)
- port b of dprams (read only) connected to other logic blocks
My problem is that after Nios writes to port a of dpram0, port b of dpram0 is not updated with the written data until Nios writes to port a of dpram1 and vice-versa.
Nios reads of port a indicate the correct data that was written.
What am I missing?
Problem solved.
Nios writes to DPRAM were cached.
