FPGA Intellectual Property
6669 Discussions
Quartus Prime 17.1 cann't program the JIC file of 4CE75 correctly when an 10AX057 and an EP4CE75 both in the same JTAG chain. The "Factory default enhanced SFL image" of Quartus Prime 17.1 may have some bugs in this situation.
XG_Kang
1、Quartus Prime 17.1 cann't program the JIC file of 4CE75 correctly when an 10AX057 and an EP4CE75 both in the same JTAG chain. The "Factory default enhanced SFL image" of Quartus Prime 17.1 may have some bugs in this situation.
2、How to make the Quartus Prime 13.1 Programmer to identify 10AX serial device? do Intel have some simple directives for the tool?
YuanLi_S_Intel
Hi 小刚 康 ,
Please find my response below:
​May i ask, have you tried to disable 10AX057 in JTAG chain and program the JIC file? Is it working?
Apologize that we dont have that. It is recommended to use the latest version for latest device.
Thank You.
XG_Kang
When Using quartus 13.1​ to load "Factory default enhanced SFL image" in EPCE75, the programming of jic file of 4CE75 is done successfully, 10AX057 is in the chain at the same time ,and programming 10AX057 is ok.
