FPGA Intellectual Property
SPOC Builder IP cores
I have a Terasic de2-70 board and am trying to modify the example code provided by Altera in the Monitor for the DE2-70 Basic Computer. According to the pdf file provided, I first need to install the SOPC Builder IP cores provided at the University Program site. I cannot seem to find these basic cores and was wondering if someone could provide a link to them.
FYI the task I am trying to undertake simply involves redefining the UART serial port pins from the MAX-232 chip on the board to the GPIO expansion port so that I can get at TTL levels. I could modify the pin assignment file in the Basic Computer verilog directory, but I am not sure that would work without a rebuild.
Thanks for any assistance that is available.
Geof
I would like to apologize for my question to the 200+ people who viewed it. It turns out that the Basic IP cores are built in when Qsys is loaded. I was able to use Qsys to convert the Basic Computer .sopc and then rebuilt it with no problem. I will next try to reassign the pins in question. Next time I will try to have a more relavent question.
Geof
