FPGA Intellectual Property
6673 Discussions
Simple CVI -> CVO System
As the title implies, I am trying to design a simple pass-thru using the CVI and CVO components.
I have a 1080p input with proper porches, actives etc; yet, I see incorrect timing parameters on the output of the CVO. For example I see a vertical front porch that is nowhere near what it should be (~30 versus 4).
The video on the monitor looks good however, yet the format it nothing close to HD.
Any suggestions on where to look?
Mike
Edit: This is in version 10.1 of SOPC/Quartus/VIP. When trying the mode change via directly writing the CVO registers, there is no response even though the mode register indicates a match...
do you work with embbeded sync or separate wire?
