FPGA Intellectual Property
6665 Diskussionen
Stratix 10 Phylite IP , deviation in data sampling at different groups(Input Path Signal)
NMR
Einsteiger
1.045Aufrufe
Hi ,
Configuration detail:
Problem Statement:
For group 0 data is sampled correctly as expected but for group 1 data to core signal the data sampled internally by phylite is shifted by 16bits(Starts sampling 2 clk earlier itself)
For checking if it's due to RTL interchanged group 0 and 1 but issue also got reversed, so not an issue from RTL rather internal sampling
So tried increasing rd latency but it only shifts the rd valid signal not the internal sampling.
Query:
Is there a method to control data sampling and address the deviation in data sampling between different groups, even though one group is a copy of the other?
Group 0
Group 1
Beschriftungen (1)
7 Antworten
NMR
Einsteiger
930Aufrufe
Hi team,
I am looking forward for your reply
Ash_R_Intel
Mitarbeiter
855Aufrufe
I think there might be something to do with the read latency. Please follow the guidance on the following webpage:
6.3.1.1. Read Latency
NMR
Einsteiger
835Aufrufe
Hi Ash_R,
Thanks for your consideration.
I checked this PHY Lite IP configuration settings with the example simulation design where I did not encounter this issue
NMR
Einsteiger
787Aufrufe
Hi Ash_R,
In dynamic reconfiguration , though I increase the tap value around mid(262) for pin input , I didn't find any delay in actual simulation .I referred the below one. Here I have doubt that how will we select the dq pin between 2 and 9.Additionally at specific pin selection (from 2 to 9) , what  I need to keep at field[8:7]?
Please help me with this
Farabi
Mitarbeiter
642Aufrufe
Bit [8:7] and bit [6:4] are used together to select DQ pins:
bit[8:4] = {2'h1, 3'h0} -> DQ0
bit[8:4] = {2'h1, 3'h1} -> DQ1
bit[8:4] = {2'h1, 3'h2} -> DQ2
bit[8:4] = {2'h1, 3'h3} -> DQ3
bit[8:4] = {2'h1, 3'h4} -> DQ4
bit[8:4] = {2'h1, 3'h5} -> DQ5
bit[8:4] = {2'h2, 3'h0} -> DQ6
bit[8:4] = {2'h2, 3'h1} -> DQ7
bit[8:4] = {2'h2, 3'h2} -> DQ8
bit[8:4] = {2'h2, 3'h3} -> DQ9
bit[8:4] = {2'h2, 3'h4} -> DQ10
bit[8:4] = {2'h2, 3'h5} -> DQ11
And about the abnormal behavior between groups, could you please run the simulation waveform showing the operation of all PHY Lite IP signals of both groups in one view.
So we can get the timing relationship of rdata_en, strobe_io, and rdata_valid of both groups in their testbench (and then check if there are any differences)
Could you please disable the dynamic reconfig in the IP and test again to see if the issue still happen?
regards,
Farabi
NMR
Einsteiger
628Aufrufe
Hi Farabi,
Thanks for detailed explanation on dq pin selection.
Below is the simulation waveform on PHY Lite IP signals for both the group 0 and group 1
Group 0
Group 1
Farabi
Mitarbeiter
543Aufrufe
  1. Disable dynamic reconfiguration in the IP and test again
  2. Do not use the group copy feature (setup group 1 manually) and test again
regards,
Farabi
Antworten
