FPGA Intellectual Property
6672 Discussions
The problem about setting up the FIFO's deep
Hi guys,
I have a big problem when I use the DCFIFO mega function. I need to store large amounts of data to achieve the data delay function. When I use the small FIFO(deep 1024),it works well. However when I increase the deeps of FIFO, it goes bad(deep 32768).(Writing and reading are not the same ) What happened ? I am confused! Is there anyone who meets the similar prolem? I'm looking forward to your suggestions! Sincere thanks!
Ive had deep fifos, and never had a problem. You will need to post more details.
Have you changed any other settings, like the lookahead mode?
Thank you for your reply!
yes, I turn on the show-ahead mode and my FIFO wide is 14bits. Did you set up any Timing Constraints for the FIFO when it gets big?
not specifically, just make sure you have constraints on both clock domains.
Can you explain it in detail? I am a novice....:oops:
I have same problem.
I use 32bit input and 8bit output FIFO, the fifo deep cannot exceed 1024 words (32768 bits).
