FPGA Intellectual Property
6670 Discussions
Tutorial: Using the USB-Blaster as an SOPC/Qsys Avalon-MM master
Hi all,
I've put together a tutorial on how to use the Altera JTAG-to-Avalon-MM master and Altera Verification IP Avalon-MM BFM Master under both SOPC builder and Qsys.
http://www.ovro.caltech.edu/~dwh/correlator/pdf/altera_jtag_to_avalon_mm_tutorial.pdf (http://www.ovro.caltech.edu/%7edwh/correlator/pdf/altera_jtag_to_avalon_mm_tutorial.pdf
http://www.ovro.caltech.edu/~dwh/correlator/pdf/altera_jtag_to_avalon_mm_tutorial.zip (http://www.ovro.caltech.edu/%7edwh/correlator/pdf/altera_jtag_to_avalon_mm_tutorial.zip
The tutorial walks the user through the creation of an SOPC or Qsys system design, and provides scripts that automate the re-generation of the system. The tutorial shows how to simulate using Modelsim-ASE, and shows how to communicate with the hardware using System Console, quartus_stp, and then how to run a TCP/IP server under System Console or quartus_stp, and then communicate with that server from client code written in Tcl/Tk (a simple GUI) and a command-line C interface.
Let me know if you like it, or have feedback/suggestions on how to improve the document.
Cheers,
Dave
Judging by the message I'm guessing the master in the system accessed something that didn't respond or the address that was used didn't exist in the system (Qsys fabric doesn't have a timeout mechanism). I would start by looking at the Qsys design and make sure the address you are attempting to access is present in the system. If you are trying to access a custom IP core then I would double check the implementation against the Avalon specification to make sure the logic is designed within spec.
Hi Erin,
--- Quote Start ---
When I open System Console, there are red x boxes by the "connections" and "devices" items in the System explorer.
--- Quote End ---
Sorry to ask the obvious, but did you download the design using the Quartus Programmer first, and then start SystemConsole?
Cheers,
Dave
Dave-
Yes I meant to mention that I did download the design first.
Erin
--- Quote Start ---
--- Quote End ---
As far as I can tell, the addresses seem right (address for the LEDs is 0x0 and I'm trying to write to that address). Can you give any advice about which specs I should check for the LED connections? It's just a PIO set for output with a bit width of 8.
Erin
Hi Erin,
--- Quote Start ---
--- Quote End ---
Could you post a screen shot of SystemConsole. I'd like to see what the messages are.
You can email it to me directly if you like. Just email it to my forum name.
Cheers,
Dave
--- Quote Start ---
--- Quote End ---
Yes I will do that later this evening. The computer on which I'm running the Quartus II is not currently connected to the internet. Thanks for being willing to help.
Erin
Just to report back to this thread, I was eventually able to get my design to work and get the board communicate with System Console, with Dave's help over email. The issue seems to have been that my CPUreset was being held low (which means reset the system) and so was continually being reset. Once I inverted this signal, the board could communicate with my laptop via System Console just fine.
Thanks all,
Erin
Quick question: I've read your nice tutorial with great interest. But I did not find any discussion relating to practical bandwidth. On a DE0-nano board, would this avalon/usb blaster interface support an average rate of 2 MB/s from board to host?
--- Quote Start ---
--- Quote End ---
Sure, I've got lots of documents ...
https://www.ovro.caltech.edu/~dwh/correlator/cobra_docs.html
The JTAG interface performance is documented in altera_jtag_to_avalon_analysis.pdf The performance is only about 600kB/s.
You can use an FTDI device, check out ftdi.pdf (60MB/s for their HS devices) and ftdi_spi.pdf (2MB/s = 16Mbps serial data rate ... might be a bit fast).
Take a read of those docs, and ask questions.
Cheers,
Dave
Thanks Dave. i read through the jtag-to-avalon document and a bunch of interesting stuff on your Cobra web site. It looks reasonably easy to impletment the JTAG, but as you said, it's not really fast enough. My intention had been to put a DE0-nano on a simple mother board with an SD card for data recording and perhaps an external USB inteface if necessary, because I'd rather avoid having to lay out and assemble a complicated multi-layer board. But this project is a retrofit that has to go inside of existing electronic boxes on our sounding rocket payload, and a more careful survey of the available volume shows that while we have quite a bit of area (we had a 6x7" board there for the previous implementation), we only have enough height for a daughter board over an area that's not quite big enough even for the DE0-nano.
So my current thought is to try the new DEO-nano-SoC, which has built-in microSD and high speed USB (using 3300 OTG chip). If I remove several extraneous connectors, it will fit nicely. It has an ARM processor side, but my first thought was to keep the power consumption low by shutting down that side and just using the FPGA. On looking at the schematics, however, it appears that both the SD card and the USB are only connected to the ARM side, so I'd have to have it running. Do you have any feeling for the minimum power it might use? Our total througput is about 150 kB/s. (I have a board on order, but not in hand yet to try.) We could go as high as 2.5 watts for the board if necessary, but thermal management will be easier if we can keep it down to a watt or so.
If the power is OK, this seems to make the implementation pretty easy. The FPGA side is reduced to a few shift registers and a FIFO. For the server end of the USB link, I looked at the libusb user-level software as you suggested (turns out it's already installed on our Linux machines), and it appears pretty straightforward to use for what we need as long as the slave end responds properly. So the main part I'm unsure of is whether the Linux that comes with the SoC-nano has something like "USB_Gadget" support that connects higher-level stuff to the 3300 chip, which by itself appears to be pretty low level.
--- Quote Start ---
--- Quote End ---
This is a newly released board, so the documentation on how to use it might be sparce or incomplete. Terasic have had the DE1-SoC and SoCKit released for a while though, so there should be enough examples for those boards.
Assuming the DE-nano-SoC can be powered from USB (I haven't checked), it should be worst-case 5V@500mA, i.e., 2.5W. I suspect it can be made to fit within your 2.5W budget. You could always test a board to see what its power requirements are, or contact Terasic and ask them.
The fact that you need to use both the FPGA and USB makes the DE0-nano-SoC sound like a reasonable fit. The other option would be an Arrow BeMicro-SDK and use Ethernet. Its a smaller PCB than the DE0-nano, but perhaps the Ethernet connector is too large?
Cheers,
Dave
Thanks for the great sharing with the tutorial.
I use Quartus 15.0.1 and Modelsim 10.3d. I tried to redefine VTAP as dut.jtag_master.jtag_phy_embedded_in_jtag_master.node but still failed to load the design qsy_system_jtag_master_tb.sv. Does anybody know to fix this problem?
Tim
Hi Tim,
--- Quote Start ---
--- Quote End ---
I suspect Altera has changed the internal implementation of their components (yet again), so the path to the JTAG tasks has changed. To determine the correct path, you could look at the code, but that is tedious ... the quick solution is to use vim to load just the Qsys system (rather than the testbench), and then use the Modelsim GUI to navigate down the component hierarchy. Once you find where it no longer matches the testbench, you can fix the path in the testbench code.
If you cannot figure it out, let me know, and I'll take a look.
Cheers,
Dave
Hi Dave,
Thanks for your suggestion. I fixed the problem after I changed VTAP with dut.jtag_master.jtag_phy_embedded_in_jtag_master.genclk1.node in tb.
Tim
Hi Tim,
--- Quote Start ---
--- Quote End ---
Glad that you managed to fix it!
Cheers,
Dave
Hi Dave,
thanks for this tutorial on how to use the JTAG Avalon MM Bridge without system console.
I would like to use the jtag_client to test functionality on our custom board that contains 2 FPGAs connected with a 2 lane transceiver link. The one FPGA is a Cyclone V SX means that I have a HPS system running Linux that can be used to act as avalon master in order to control my custom components.
The other FPGA is a GX device that should act as co-processor for the SX and data will be transmitted between both withe the aformebtioned transceiver link.
Now, I'm looking for a way to access this GX device with your jtag_client implementation. I successfully startet the tcl version and also compiled the little C applikation.
In both approaches, I'm missing the possibility to tell which device on the JTAG bus I would like to actually talk to.
Is there a way to do this?
Maybe to clarify what I mean:
when I run jtagconfig -d, it shows this:
developer@ad-rts-devel:~/altera_jtag_to_avalon_mm_tutorial/tcl/jtag_client_server$ jtagconfig -d
1) USB-Blaster [1-2]
4BA00477 SOCVHPS (IR=4)
02D020DD 5CSEBA6(.|ES)/5CSEMA6/.. (IR=10)
Node 30006E00 SignalTap# 0
Design hash 3BFD7E53824943D21A48
02B030DD 5CGTFD7(B5|C5|D5)/5CGXBC7B6/.. (IR=10)
Captured DR after reset = (4BA0047702D020DD02B030DD) [96]
Captured IR after reset = (155555) [24]
Captured Bypass after reset = (0) [3]
Captured Bypass chain = (0) [3]
JTAG clock speed 6 MHz
Now, I would like to access the device with the ID "02B030DD 5CGTFD7(B5|C5|D5)/5CGXBC7B6/.. (IR=10)" with your jtag_client script or application.
I'm sorry, if you already mentioned this in your documentation, but so far I havn't found that information myself.
Maik
Okay, sorry, I think I got it.
It does not finally run which maybe because I have not finished my FPGA configuration, but I think I understand how it should work:
I first have to start the jtag_server.tcl and after that I can use the jtag_client.tcl to access the JTAG to Avalon Master Bridge in my FPGA design, right?
And in order to get the server connected to the desired device on my JTAG Chain, I have to edit the jtag_open function and use device 2 instead of 0, right?
After that I should just be able to access the avalon slaves via JTAG in my FPGA with the jtag_client software, right?
Maik
Hi Maik,
--- Quote Start ---
--- Quote End ---
Yes. I'm pretty sure I made the client as simple as possible, i.e., if the server was not there it does not keep retrying the connection. You could easily add retry functionality, but I would recommend putting a delay in between retries.
--- Quote Start ---
--- Quote End ---
The indexing starts from 0, and since you want to access the second device, you will want index 1.
--- Quote Start ---
--- Quote End ---
Yes, that sounds correct.
Cheers,
Dave
Hi Dave,
yes, I managed to start the server succesfully and let it connect to the JTAG Master interface in my design.
I also managed to connect the client to the server.
Unfortunately, I get an "Invalid command from the client" error when I try to send write requests. When I try to send read requests, the client GUI freezes.
Attached is a screenshot of the client/server running with the mentioned error.
In my GX FPGA, my component is connected to the JTAG to avalon Master Bridge as it is connected to the HPS in the SX FPGA, where the communication with my custom component just works from the HPS/Linux interface.
I also attach a screenshot of my system. I am also not able to access the xcvr or reconfiguration component on their avalon slave interfaces...
I looked for that error message in your server source and found that it was not even transmitting anything to the JTAG interface, because it already had problems before the actual write command. But I don't know, if this is the correct interpretation of the source code.
Maybe you can help and tell me what I am doing wrong, here.
Maik
Hi Maik,
Take a look at the server code. If you start the server in debug mode it just accesses a Tcl variable. Use that mode to debug what the clients are doing.
Start with just one client, and then check that it works. If you start a second client and it breaks, the issue could be related to the server handling of multiple clients.
At some level this type of debugging gets too complicated ... not that using clients and servers is hard, but that Altera does not provide sufficient information to "design" everything nicely.
If your hardware has a UART or FTDI interface, then you can write actual client/server code that will be more robust than using Altera's Tcl interfaces - some of which are broken and useless due to their use of Java.
If you do want some advice on how to implement your system, feel free to ask here on the forum, or if you do not want to discuss your project in public, send an email to my forum name.
Cheers,
Dave
PS. The forum resampled your images when you uploaded them, so they are too small and unreadable.
