FPGA Intellectual Property
6673 Discussions
What is Altera library for 16 bit Shift Register LUT with Clock Enable
I want to change from Xilinx desing code to Altera.
But, I don't know what is altera library for following two xilinx library.
If you konw it, let me know.
1) 16 Bit Shift Register Look-Up-Table(LUT) with clock Enable
(http://toolbox.xilinx.com/docsan/data/alliance/lib/lib10_10.htm
2) 2 to 1 Multiplexer for Carry Logic with General Output
(http://toolbox.xilinx.com/docsan/data/alliance/lib/lib7_33.htm
For the first one, there isn't an exact replacement, you may design a wrapper to port existing code, if necessary. The second one is a very basic element that wouldn'n be instantiated directly to my opinion. But you possibly can find a replacement in primitives library.
I noticed, that Xilinx mentioned inference recommended with both components, in other words, they assume that you let the HDL compiler choose a suitable library component. In this case, you don't have to worry much how to port the code to another FPGA family.
I strongly agree with FvM. These components can all be inferred, and the coding is much easier and more understandable. Fot the sift register, there is a megafunction call altshift_taps that makes shift registers out of memories. I don't recommend instantiating that either, but letting Quartus infer them. If you go to Assignments -> Settings -> Analysis & Synthesis -> More Settings -> Auto Shift Register Replacement, which is set to Auto. On some X designs I've converted where the user instantiated this, I put in an RTL model, let Quartus figure it out, and ended up using less logic because of it(but a little extra memory.) Here's a model that should help:
module SRL16E(Q, A0, A1, A2, A3, CLK, D, CE) ;
input A0, A1, A2, A3, CLK, D, CE;
output Q;
reg [15:0] shift_reg;
reg Q;
always@(posedge CLK)
begin
if (CE)
shift_reg <= {shift_reg[14:0],D};
end
always @ (A3 or A2 or A1 or A0 or shift_reg)
begin
case ({A3, A2, A1, A0})
1 : Q = shift_reg[1];
2 : Q = shift_reg[2];
3 : Q = shift_reg[3];
4 : Q = shift_reg[4];
5 : Q = shift_reg[5];
6 : Q = shift_reg[6];
7 : Q = shift_reg[7];
8 : Q = shift_reg[8];
9 : Q = shift_reg[9];
10 : Q = shift_reg[10];
11 : Q = shift_reg[11];
12 : Q = shift_reg[12];
13 : Q = shift_reg[13];
14 : Q = shift_reg[14];
15 : Q = shift_reg[15];
default : Q = shift_reg[0];
endcase
end
endmodule
