I want to change from Xilinx desing code to Altera.
But, I don't know what is altera library for following two xilinx library. If you konw it, let me know. 1) 16 Bit Shift Register Look-Up-Table(LUT) with clock Enable (http://toolbox.xilinx.com/docsan/data/alliance/lib/lib10_10.htm) 2) 2 to 1 Multiplexer for Carry Logic with General Output (http://toolbox.xilinx.com/docsan/data/alliance/lib/lib7_33.htm) ThanksLink Copied
For the first one, there isn't an exact replacement, you may design a wrapper to port existing code, if necessary. The second one is a very basic element that wouldn'n be instantiated directly to my opinion. But you possibly can find a replacement in primitives library.
I noticed, that Xilinx mentioned inference recommended with both components, in other words, they assume that you let the HDL compiler choose a suitable library component. In this case, you don't have to worry much how to port the code to another FPGA family.- Mark as New
I strongly agree with FvM. These components can all be inferred, and the coding is much easier and more understandable. Fot the sift register, there is a megafunction call altshift_taps that makes shift registers out of memories. I don't recommend instantiating that either, but letting Quartus infer them. If you go to Assignments -> Settings -> Analysis & Synthesis -> More Settings -> Auto Shift Register Replacement, which is set to Auto. On some X designs I've converted where the user instantiated this, I put in an RTL model, let Quartus figure it out, and ended up using less logic because of it(but a little extra memory.) Here's a model that should help:
module SRL16E(Q, A0, A1, A2, A3, CLK, D, CE) ; input A0, A1, A2, A3, CLK, D, CE; output Q; reg [15:0] shift_reg; reg Q; always@(posedge CLK) begin if (CE) shift_reg <= {shift_reg[14:0],D}; end always @ (A3 or A2 or A1 or A0 or shift_reg) begin case ({A3, A2, A1, A0}) 1 : Q = shift_reg[1]; 2 : Q = shift_reg[2]; 3 : Q = shift_reg[3]; 4 : Q = shift_reg[4]; 5 : Q = shift_reg[5]; 6 : Q = shift_reg[6]; 7 : Q = shift_reg[7]; 8 : Q = shift_reg[8]; 9 : Q = shift_reg[9]; 10 : Q = shift_reg[10]; 11 : Q = shift_reg[11]; 12 : Q = shift_reg[12]; 13 : Q = shift_reg[13]; 14 : Q = shift_reg[14]; 15 : Q = shift_reg[15]; default : Q = shift_reg[0]; endcase end endmodule
